3W-140 Problem
Keith Mitchell
3W-140 Problem
Postby Keith Mitchell » June 16th, 2009, 4:25 pm
Does anybody know what the adhesive/sealant is that sticks/seals the reed valve housing to the inside of the crankcase?
K.
Keith Mitchell
Re: 3W-140 Problem
Postby Keith Mitchell » June 21st, 2009, 10:32 pm
I've sorted the problem (rough running, poor starting). It was in the joint between the crankcase and the reed-valve frame. The original jointing compound was failing allowing leakage around the reeds.
Cleaned-off the old compound and re-jointed with 'Universal Blue' (Hyalomar) - available from motor factors. It is a sealant/jointing compound that is impervious to virtually all industrial fluids and works up to high temperatures.
The substance has an interesting history. Developed by Rolls-Royce 40 years ago for sealing joints in jet engines, the patent expired 20 years ago and RR stopped producing it. A German company obtained the rights and now make it and sell it all over the World.
Why don't we make anything anymore --------------?
Users browsing this forum: No registered users and 59 guests
