Re: Mick reeves torquemaster .
karl lawrence
Postby karl lawrence » May 20th, 2015, 12:00 pm
Hi. Has anybody fitted a mick reeves torquemaster to a zenoah 62 with the electronic ignition. All the info and pictures I can find show it fitted to the older magneto engines. If anybody has done it any info, pictures of it fitted would be great. Also do I need any other parts to make it all fit as the prop driver for the electric ignition and magneto one are different so I'm struggling to see how it would fit. Many thanks karl
Postby David Brown » May 20th, 2015, 2:10 pm
It should all fit the same, the Rcexel prop driver replaces the magneto and the pulley/flywheel of the torquemaster bolts on as normal. Just be aware that on the Rcexel prop driver there is sometimes a slight bulge in the face due to the magnet being pressed in, I just fettle it back flush before bolting on the main prop hub or pulley in your case.
Hope this helps
Postby David Brown » May 20th, 2015, 2:30 pm
Here's one I made earlier :D . just checked and yes it does fit.
MR Drive 002.JPG (129.92 KiB) Viewed 4191 times
MR Drive 003.JPG (172.41 KiB) Viewed 4191 times
MR Drive 004.JPG (174.83 KiB) Viewed 4191 times
karl lawrence
Postby karl lawrence » May 20th, 2015, 3:25 pm
Thats great. Was looking at the rcexl flywheels last night and assumed that'd be the way to go. Just need to persuade her indoors now to let me buy the torquemaster lol.
