1/3 Spitfire
Re: 1/3 Spitfire
Postby David Brown » November 4th, 2018, 9:40 am
At last after 3 years I have the reduction drive sorted and running on the ZDZ 210. It can be viewed on my time line on face book or YouTube under ZDZ 210. I will sort out the picture sizing and post them later.
Re: 1/3 Spitfire
Postby David Brown » November 8th, 2018, 2:21 pm
This is the sketch on Solid works to design the engine lay out
3rd spit setup.jpg (272.47 KiB) Viewed 1194 times
Re: 1/3 Spitfire
Postby Cary Bailey » November 9th, 2018, 6:09 pm
Lovely work Mr Brown!
Re: 1/3 Spitfire
Postby David Brown » November 15th, 2018, 5:45 pm
I finally got time to resize the images I had of the drive build. This is the drive coupling I designed for the drive assembly to take all of the side load off the engine front bearings along with its purpose to push the engine back onto the firewall.
Re: 1/3 Spitfire
Postby David Brown » November 15th, 2018, 5:53 pm
This is the assembly built up. The back mount plate took some making as ZDZ's machining of the rear mount was not concentric with the centerline of the engine and I had to use cam bushes to true it all up. since the initial runs which were very impressive I have not found the time to manufacture the exhaust to do the full running in of the engine.
Re: 1/3 Spitfire
Postby David Brown » January 19th, 2020, 9:34 am
After another factory unit move in 2019 I have more space to get on with the bigger projects I have on the go. The Spitfire is now on her wheels and the engine fitted. I am looking to get her test flown later in 2020
Re: 1/3 Spitfire
Postby David Brown » January 19th, 2020, 9:38 am
On her wheels
Re: 1/3 Spitfire
Postby David Brown » January 20th, 2020, 12:31 pm
https://www.facebook.com/10000695350103 ... 61768/?t=5 if this link works it is the test run of the completed engine.
