Walbro carb suppliers - UK ????
DavidBanks
Postby DavidBanks » June 24th, 2015, 12:12 pm
I have a CRRC 50 GFi (don't laugh!) and the carb is completely worn out.
Its a Walbro WT951 - 805 but I cant find a supplier of one in the UK for love nor money.
Anyone know of anywhere worth trying ???
Given that a replacement engine complete is £230 its not the end of the world but its a cracking wee engine and it seems a shame to relegate it to parts for the lack of a carb.
Stuart Solomon
Re: Walbro carb suppliers - UK ????
Postby Stuart Solomon » June 24th, 2015, 12:19 pm
Try Falcon Aviation.
Peter Siggins
Postby Peter Siggins » June 24th, 2015, 12:28 pm
Could also try Rowena motors in Bangor N.Wales - have a website detailing parts etc.
Steve Mansell
Postby Steve Mansell » June 24th, 2015, 7:45 pm
I have a walbro that was on a Zen 45. engine used for spares. I can't see a number on it, but if it's any good you can have it. The high & low needles are bent and need replacing, but if it's the same model just swap them over.
Postby Alan Cantwell 1131 » June 24th, 2015, 8:23 pm
How is it worn out? Give me the hole centres, a zenoha one may do
DavidBanks
Postby DavidBanks » June 24th, 2015, 8:59 pm
Thanks guys - Rowena can get me one (eventually) but at £100 its a non-starter - a complete new engine is £230 !!
Falcon havent replied yet.
The carb body is so worn where the throttle spindle is bushed that its impossible to get steady idle and mixture settings. It's got a good number of hours on it !!
The mounting holes are 30.81mm centres and its the type that has a nipple for a pressure line from the crankcase for the pulse.
The numbers stamped on it are WT 951 and beneath that 805
Thanks for all your help.
Postby Tony Collins 1073 » June 25th, 2015, 9:48 am
Dave, I have had this problem over the years and the easiest remedy is simply to make a new throttle spindle and make it match the holes in the carb. It is not a long job and if you don't have
the means to do it yourself maybe you could get it done for you. Much cheaper than a new engine
or carb.
Tony.
Postby sean smith » June 25th, 2015, 5:09 pm
DavidBanks
Postby DavidBanks » June 26th, 2015, 12:54 pm
Thanks Sean - perfect !!!!
Order placed - :D :D :D
Users browsing this forum: No registered users and 50 guests
