Gelcoat
Gelcoat
Postby sean smith » August 14th, 2015, 6:02 pm
Can anyone advise on a good gelcoat to use for making glassfibre cowls?
Robin Woodhead
Re: Gelcoat
Postby Robin Woodhead » August 15th, 2015, 12:32 pm
Depends on what resin you are going to use.
If using polyester, the supplier will also have the appropriate product.
Same goes for Epoxy, Polyester and Epoxy do not mix.
Re: Gelcoat
Postby sean smith » August 15th, 2015, 10:14 pm
Hi Robin,
I'll be using epoxy resin, just wondering what was popular with modelers?
Stuart Solomon
Re: Gelcoat
Postby Stuart Solomon » August 16th, 2015, 8:26 pm
Glen at GLENS MODELS used to use a white gelcoat which was compatable with epoxy. Came from Germany in gallon pots. Might be worth a try ?
Re: Gelcoat
Postby sean smith » August 16th, 2015, 9:06 pm
Thanks, i'll look into it.
Re: Gelcoat
Postby Phil Clark » August 22nd, 2015, 9:04 pm
I mix my own from West 105 resin, colloidal silica (to thicken) and a small amount of grey epoxy pigment.
The silica has to be mixed mechanically to get best results......to do this, make a small but stiff wire hook and use it in a Dremel. If you mix only by hand, the silica doesn't mix fully in. You know when it's mixed as it turn a nice smooth glossy colour.
HTH
