Casting rubber for tyres
Dave Osborne
Postby Dave Osborne » September 16th, 2015, 8:08 pm
I am interested in making my own tyres but would like to know which type of casting rubber to use.
Many thanks Dave
Stuart Solomon
Re: Casting rubber for tyres
Postby Stuart Solomon » September 17th, 2015, 9:54 am
Dave, Dunlop 'FLEXANE' comes in different grades, get super fine detail from it. Solly
barrie burton
Postby barrie burton » September 17th, 2015, 1:57 pm
Thanks Stuart,you may have the solution for my post re leaking Dubro wheels.
Barrie B
Dave Osborne
Postby Dave Osborne » September 20th, 2015, 10:41 pm
Thanks for the info, I recall flexane from my aircraft engineering days but had not thought of it. I will look into it.
cheers.
Rob Crawford
Postby Rob Crawford » July 12th, 2016, 6:58 pm
Here's how i do it with PT flex(available in the UK):
Tyre plug 1.JPG (100.49 KiB) Viewed 7793 times
Tyre plug 2.JPG (79.81 KiB) Viewed 7793 times
Tyre plug template.JPG (65.14 KiB) Viewed 7793 times
Tyre plug 3.JPG (99 KiB) Viewed 7793 times
Tyre plug finished.JPG (87.77 KiB) Viewed 7793 times
pt flex.JPG (47.67 KiB) Viewed 7793 times
tyre in mold.JPG (79.16 KiB) Viewed 7793 times
Rob Crawford
Postby Rob Crawford » July 12th, 2016, 7:07 pm
Looks well on the rim,the only mistake i made with this one was put the vent holes on the front.
The only thing i didn't take a picture of (because this stuff goes off fast)was the foam core i cut out and placed in the mold before pouring the rubber,a solid rubber tyre is far to heavy.
forum pic 1.jpg (83.07 KiB) Viewed 7792 times
Postby David Brown » July 13th, 2016, 7:05 pm
Great job done there, worth all of the time put in to get such a good result.
Rob Crawford
Postby Rob Crawford » October 11th, 2016, 9:18 am
Thanks David
You can get the pt flex online say ebay or their website.
I used 60 shore for mine which is fine but you could go to 70 shore with no problems, at around £25 for about eight tyres worth i found it to be very cost effective.
If you have trouble getting the stuff i could get it from their store local to me and send it to you.
Simon Illsley
Postby Simon Illsley » January 12th, 2017, 7:13 pm
Hi Rob Crawford I have sent you a PM
