Wanted compressor wheel for Jetcat P120
Philip Goff
Postby Philip Goff » May 4th, 2016, 8:16 am
Dear All
As mentioned in the title, does anyone have or know where I can get
a compressor wheel for Jetcat P120 please the engine is about 12 years old.
The engine has worked faultlessly in our MR Lightning.
While carrying out routine maintenance yesterday, I noticed
that a small piece had broken off one of the compressor blades.
Thank you.
Regards Phil G.
Re: Wanted compressor wheel for Jetcat P120
Postby Rob Buckley » May 4th, 2016, 11:55 am
Jetcat have them, they fitted a new one to mine when it did the same thing.
Postby John Greenfield » May 5th, 2016, 7:29 am
you cant just unbolt the old compressor and fit a new one without rebalancing the whole compressor, turbine wheel and shaft and this requires disassembly of the whole motor. I would suggest you send it to back to Jetcat or one of their approved service centres to have the job done properly.
Dave Wilshere
Postby Dave Wilshere » May 8th, 2016, 6:50 pm
He's already had that conversation ;-)
jetCat have a balancing rig that is very special, also such an old turbine probably has a steel combustion chamber that will likely be a bit of a mess. As always JetCat quote on the job before anything is done, so you have the chance to decide the repair is not economic!
Philip Goff
Postby Philip Goff » May 14th, 2016, 9:40 am
Dear All
Thank you all for your valued advice.
The engine is now on the road to recovery.
After last weekends traumatic events, I had forgotten about this thread.
Regards Phil Goff
Return to “Jets”
