Postby RegHomden » August 3rd, 2009, 10:30 pm
Hi Stuey,
I am not sure if I should use 4 EDFs or a jet. The problem with a jet is where or how to do the jet pipes. At the moment I have four jet pipes, each of 60mm diam. Any advice would be very much appreciated. As it is, without servos, engines or receiver it weighs 9 kilos. That may sound slightly heavy but most of it is double skinned ( 2 layers of 2mm balsa). I live in madrid and all ao my materials come on metric dimensions.
I have very limited experience with building model aircraft. So far I have built :
A 1/7th scale Sea Fury form Tower Hobbies that was a superb kit with instructions that enabled even a novice to build a fantastic aircraft that flies fantastically.
A 1/6th Scale Spitfire from a crap kit that lacked many essential parts and almost no instructions. The good news was that, being so bad, it taught me a lot and now it looks fantastic and flies even better than the Sea fury - and gave me the confidence to tackle the Vulcan fro0m scratch.
Just thought you might like to see the undercarriage that I have just built :-)
- I know that the full size vulcan has 8 wheels on each main leg but .......
- UC4.jpg (38.47 KiB) Viewed 11598 times
