Wellington
Dave Collis 2296
Wellington
Postby Dave Collis 2296 » September 29th, 2016, 4:14 pm
After searching the forum for the build threads etc on the Wellington, I assume all the info was lost due to the new website?
I am just starting to build mine and am curious as to which engines and props the guys are using. I just looked at the you tube video of the 5 Wellingtons flying...wonderful!!!
Dave.
Re: Wellington
Postby Rob Buckley » September 29th, 2016, 5:52 pm
Re: Wellington
Postby Dave Parry » September 29th, 2016, 7:30 pm
There has been two Wellington builds in the LMA Journal one in the last issue which is also on this forum as Rob as pointed out with a link.
Dave Collis 2296
Re: Wellington
Postby Dave Collis 2296 » September 29th, 2016, 9:37 pm
Thank you, gents.
I'd found some of the words but was missing the pictures.
Dave.
Steve Vodrey
Re: Wellington
Postby Steve Vodrey » November 16th, 2016, 8:27 am
Hi Dave.
To answer your question about engines and props on the Wellingtons. Mine (and just about all the others) use Zenoah 26 engines mounted inverted.
Props on mine are 16/10 three blade G Sonic. The others favour 16/8 three blade.
Dave Collis 2296
Re: Wellington
Postby Dave Collis 2296 » November 16th, 2016, 3:08 pm
Hi Steve.
G 26's are rare as hens teeth in Canada at the moment, no one has any in stock, even Horizon in the US is out of stock.
I have ordered a pair of RCGF 26's...RCGF seems to have a pretty good reputation in the US., plus I can buy a pair for about $100.00 more than a single G 26 up here in Canada
I also have the 16/10 G- sonic props.
Starting to gather radio gear etc.
My Welly is coming along, fuse 50% done, wings framed and fitted ( starting some sheeting), tail surfaces framed and fitted, landing gear from Kingfisher is here, cowls from Vortex...very nicely done, by the way.
I'm at the decision point as to what to do with the bomb bay, so I spend a lot of time staring at the plans,,,thinking...lol.
Re: Wellington
Postby Rob Buckley » November 16th, 2016, 6:12 pm
To make a bomb bay that's even vaguely scale would be a complete nightmare...so I didn't bother and just put a hatch in the bottom to get to the wing fixings
Steve Vodrey
Re: Wellington
Postby Steve Vodrey » November 18th, 2016, 8:53 am
Hi Dave.
It can be very time consuming constructing bomb doors and if they are true to scale they take away a great deal of the strength of the fuselage.
I made mine to scale but shorter if that makes sense. They are not hinged but are removable if needed to get to the inside as Rob said.
Dave Collis 2296
Re: Wellington
Postby Dave Collis 2296 » November 18th, 2016, 3:17 pm
Hi Steve.
I think that is what I'll do.
Thank you.
Dave.
Dave Collis 2296
Re: Wellington
Postby Dave Collis 2296 » January 26th, 2017, 5:05 pm
What are you gents using for a tail wheel retract?
I've given up on Kingfisher and no joy from Unitracts, but I was contacted by Dave Brown (Thank you, Dave)who stated he had not had any call for a Welly t/wheel retract unit but would see if anything suitable could be found.
I've heard nothing back from Dave to date.
Dave.
Re: Wellington
Postby Rob Buckley » January 27th, 2017, 7:13 am
I was just using a standard '40' size model nose gear electric retract. Most don't retract the tailwheel.
Re: Wellington
Postby DAVE JOHNSON » January 27th, 2017, 8:20 am
Dave---as above---I used the standard wire sprung trainer noseleg----it was easy to install on a bulkhead and it works great-----DAVE
Dave Collis 2296
Re: Wellington
Postby Dave Collis 2296 » January 27th, 2017, 2:47 pm
Thank you, Gents.
Dave.
