Thye above pics show the sides which are epoxied onto the 3/8" ply undercarriage plate ,which is the start of assembling the fuselage.I made a mistake earlier that the fuse sides 1/4" balsa sheet finshes after the rear door and has 1/4" x 3/8" longerons spliced into the sheet to the tail end.
- m_DSCF0704.jpg (19.4 KiB) Viewed 22325 times
This shows the size of the front door which was sealed up again
- m_DSCF0742.jpg (17.67 KiB) Viewed 22325 times
This is the rear door which I kept but reduced its size slightly
- m_DSCF0743.jpg (26.23 KiB) Viewed 22325 times
The rear door opening with trial seat in place
- m_DSCF0744.jpg (29.4 KiB) Viewed 22325 times
the rear door with blocks glued in to screw hinges onto
- m_DSCF0745.jpg (20.28 KiB) Viewed 22325 times
The rear door hinged - hinges fro B&Q cut down to size.
I made an instrument panel from bits i had in draws - not necessarily scale but look reasonable
- m_DSCF0741.jpg (22.97 KiB) Viewed 22325 times
The rear seat made from blus foam tried in place
I have lost a number of pics showing the construction of the wing joiners and the method of strengthening the assembly with 1/8 piano wire which is across front and rear wing joiners ab=nd notched into the spruce uprights - the following pic shows after all this assembly has been comleted
- m_DSCF0778.jpg (35.22 KiB) Viewed 22325 times
The top is now solid and as can be seen the 3/8" wing attachments fitted
if still OK i'll post more later
