tomahawk futura 2.5 turnkey
Mike altham
Postby Mike altham » November 2nd, 2016, 10:38 pm
Very reluctant sale but needs must and change of direction. I have to much money tied up in models so some are having to go.
Since I have had it I have done the following.
I stripped the complete frame back to gel coat and stripped everything out of it.
I RE wired everything with hd silicone wire and put on new plugs etc.
6 new 8911 servos and one 8921 on the rudder 8411 on nose leg, all new linkages and h9 alloy arms, has the tomahawk retracts and brakes, tomahawk tank, map uat, has a new powerbox cockpit srs with 4 sats, new optipower ecu pack, powerbox 2800 lipos x 2, powerbox smoke pump, jetcat 180rxi with around 2.50 mins run time on it. (Will have to check). Jet cat spektrum telemetry not yet fitted. Also has the mini gsu. Jettronic gear and brake valves, two schrader fillers to two separate air systems and pressure gauge.
Also added the colour scheme which is all vinyl so can be taken off if not to someone's taste.
Modded the fin as they normally have one fastener on the front so I added an extra one to make it solid.
Fly's mint and has the futura howl since I have finished it I have know had a few flights on it but I have a new model for next season and have the Nimrod to finish.
£5500 turnkey on spectrum dsmx and can supply dx18 settings
or £2000 for engine and £3500 for airframe
