Wanted - engine mod cost
Postby richard armstrong » December 17th, 2016, 1:56 pm
hi all
i have a moki 30cc with a bell engine mount, Spoken to steve mackay about replacing the back plate but this engine has been out of production for 15 years?
so, would like to ask if one of the many engineers could help me ? i have a lathe but this beyond my scope of knowledge and no milling machine
what i would like to is either to have the back plate remade or the bell mount milled down to accommodate a beam mount, and remove as much of the bell without compromising the back plate
also with the bell mount in place i cannot fit a pitts exhaust
what would it cost to have a back plate made ? or mill down bell mount
alternative if anyone has a moki 30cc (180) engine as spares or repairs could they please let me know?
all advice welcome!
Re: Wanted - engine mod cost
Postby stuart knowles 1611 » December 17th, 2016, 3:25 pm
Well, the beam mounts are there on the crankcase, so being a heathen, if twer mine I would attack the bell mount with a hacksaw and an angle grinder (Both precision tools in my workshop) and separate mount from back plate and Roberts your fathers brother.
Probaby wont be pretty so make sure that there's no other way to use the existing mount.
Proper Engineers will be shaking their collective heads at this point.
Postby richard armstrong » December 17th, 2016, 5:12 pm
i did think of what u suggesting Stuart, but i want it done correctly as with the mount the engine is too long for cowl and the mount will not fit the firewall, without causing too much hassle to change firewall and a major mod of the front end
simple route in this case back plate to be milled allowing beam mount at present it far too long and a pain in the rectum, trying to use what i have in stock and not purchase a 26cc for the extra 260 i am refurbishing
Postby Alan Cantwell 1131 » December 17th, 2016, 5:34 pm
You need a simple backplate turning, i cant help, i am not in work at the moment, being off sick,but its a simple enough job for any machinist we have in the ranks, i would not destroy the backplate mag, once its gone, it cannot be replaced
Postby richard armstrong » December 17th, 2016, 5:54 pm
Alan Cantwell 1131 wrote:You need a simple backplate turning, i cant help, i am not in work at the moment, being off sick,but its a simple enough job for any machinist we have in the ranks, i would not destroy the backplate mag, once its gone, it cannot be replaced
sorry to here you are sick alan, i am in no hurry, but if anyone can help, that would be great!
paul hughes
Postby paul hughes » December 17th, 2016, 6:42 pm
What model is this for Richard? It seems to me that if the mount is too big for the firewall then the engine is too big for the model.
Postby Alan Cantwell 1131 » December 17th, 2016, 6:58 pm
Had many instances Paul, of the super tigre 3000 series being to big physically, with the radial mount on, but fitted great wirh the backplate fitted
Postby Rob Buckley » December 17th, 2016, 7:57 pm
Just hacksaw off the bits you don't like the look of and file it to look pretty again. If you're keen to do it properly, you could even take it off the engine first!
Dave Berry 2911
Postby Dave Berry 2911 » December 17th, 2016, 8:53 pm
Don't forget that there's a boss cast into the backplate which is blind drilled for the Hall sensor which is epoxied in. The latter is triggered from the crankpin just the other side of the aluminium. If you make a 'standard' backplate you will have to make alternative provision for triggering the HT.
Postby richard armstrong » December 17th, 2016, 9:21 pm
Dave Berry 2911 wrote:Don't forget that there's a boss cast into the backplate which is blind drilled for the Hall sensor which is epoxied in. The latter is triggered from the crankpin just the other side of the aluminium. If you make a 'standard' backplate you will have to make alternative provision for triggering the HT.
hi dave, thanks for the input
hence why i need someone to do this properly and not just hack at it, as for the ht lead and i did thing of doing to mod for a hall censer and magnet on the prop drive, and update the moki CDI to a RXECL CDI unit i have spare that was one option i had in mind but i just want to keep it simple
but i what just thinking of just milling the bell mount down, but i don;t have a mill
as for the engine not fitting if the bell mount was not there it would fit perfect and mount lovley on a 150 beam mount
airframe 26 - 30cc extra 260 70",
Rosario Iannotti
Postby Rosario Iannotti » December 18th, 2016, 12:44 pm
Hi all first time on this forum, it looks a simple enough job you could simply do it in the lathe if you only need to take it down to the original bolt holes you could use 3 or 4 jaw chuck use aluminium shims to protect use a parting tool to remove most of the material and finish off with a cutting tool flush to the desired depth, I hope this helps
Ross
Postby richard armstrong » December 18th, 2016, 1:14 pm
Rosario Iannotti wrote:Hi all first time on this forum, it looks a simple enough job you could simply do it in the lathe if you only need to take it down to the original bolt holes you could use 3 or 4 jaw chuck use aluminium shims to protect use a parting tool to remove most of the material and finish off with a cutting tool flush to the desired depth, I hope this helps
Ross
thanks rosario
but my skills with a lathe are basic at best i prefer a PRO engineer do the job i really dont want an half baked cock up of a mess.
so over to the engineers i was hoping dave from kingfisher was about dont have his contact details?
Postby stuart knowles 1611 » December 18th, 2016, 1:31 pm
Richard,
Have a look in the 'member services' section of the journal. There is a guy in there offering machining skills. Might be worth a chat with him??
Postby richard armstrong » December 18th, 2016, 1:49 pm
stuart knowles 1611 wrote:Richard,
thanks Stu
Rosario Iannotti
Postby Rosario Iannotti » December 18th, 2016, 1:57 pm
Ok, if the pickup sensor comes off send it to me mark how much you want off and I'll do it for yo
Ross
Postby richard armstrong » December 18th, 2016, 2:18 pm
moki engines have the sensor inboard see pics, not sure if they are fixed to the back plate ?
Rosario Iannotti
Postby Rosario Iannotti » December 18th, 2016, 2:28 pm
Ok that's fine, just take the backplate off remember original orientation so your timing is right mark how much you need taking off and I will do it for you.
Ross
Postby richard armstrong » December 18th, 2016, 4:04 pm
Rosario Iannotti wrote:Ok that's fine, just take the backplate off remember original orientation so your timing is right mark how much you need taking off and I will do it for you.
Ross
i will be in touch ross shortly
Rosario Iannotti
Postby Rosario Iannotti » December 18th, 2016, 4:53 pm
Sorry I haven't introduced my self well you know my name I am member of DDMFC and Neil Dixon being our chairman also member of the LMA I have been club member for the last 15 years sorry but I thought I should have done this before I made any comments on the website
Ross
