Ziroli P51
John Webb
Ziroli P51
Postby John Webb » April 28th, 2017, 10:28 am
Advice please. Son Jason and I have recently acquired an almost complete Ziroli 51 which needs a lot of remedial work before flight. I have just had to make a new front bulkhead and reinforce the sideframes to take the bellhousing of a Xenoah 62.
As built the original bulkhead had no downthrust or sidethrust. Zero, zero. Have been able to borrow a plan from Paul Dudley and it shows no side thrust, but although the plan is a bit unclear it appears to show a tad of down thrust, no mention of dgrees.
The new bulkhead now has just a tad of down thrust and the spinner seems to match the top of the cowling OK.
Any advice please as to what is correct in practice from those who have flown them.
For what it's worth my CompARF P51, same size flies perfectly well on zero zero down/sidethrust
John Webb 800
Re: Ziroli P51
Postby Cary Bailey » May 2nd, 2017, 5:27 pm
Hi John, the Ziroli P51 plan/instruction booklet advises that it has no downthrust and approximately 2 degrees of sidethrust. However this is based upon the engine size that the original design was based upon. I would think you need to apply a small amount of downthrust and sidethrust, probably 2 degrees of each as a guide.
John Webb
Re: Ziroli P51
Postby John Webb » May 2nd, 2017, 5:51 pm
Thanks Carey. At the moment I've got a tad of down and no sidethrust. Been talking to Stewart Clifford who has a lot of experience with the Ziroli. He reckons zero zero so it's all a bit variable. I think I'll stick with what I've done so far and see how it goes.
Thanks for your help
JOHN
Re: Ziroli P51
Postby Phil Clark » May 2nd, 2017, 7:29 pm
I'd go with Carey's suggestion......no down & around 2 deg of side.
Users browsing this forum: No registered users and 76 guests
