1/5th OV 10 Bronco
Re: 1/5th OV 10 Bronco
Postby Dave Parry » October 17th, 2018, 8:17 am
Chris Bradbury wrote:
Dave Parry wrote:Looking really good Chris, would love the full story for the Journal if you ever fancy having ago. My contact is at the bottom of my posts and in the Journal.
Good luck with the rest of the build.
Dave (LMA Journal Editor)
Be happy to write something up once it's all finished and we can get the important flying photos.
Great, will look forward to it.
Chris Bradbury
Postby Chris Bradbury » October 25th, 2018, 9:01 pm
I've started adding a few more components that are easiest added at this stage of the build, which in this case is the lighting.
The OV10 has a single beacon light on the top of the horizontal stab, so this has been fitted. Sequence wise I've programmed this with a UniLight 8 channel controller.
The UniLight controller
The tail beacon light recessed in to the skin of the rear stabiliser.
BMFA Examiner
Chris Bradbury
Postby Chris Bradbury » October 26th, 2018, 10:57 pm
A little bit off work done on the centre main wing section tonight.
I've added a 3mm ply reinforcement under the skin of the wing where the bolts will go through to mount to the centre fuselage.
Gluing in place
View from above
View from inside the wing. This will have a solid balsa fill as well.
Top wing skin applied.
Flaps started, which now need the leading edge attaching.
BMFA Examiner
Chris Bradbury
Postby Chris Bradbury » October 29th, 2018, 12:54 am
Focussed on the centre wing section today.
Flap leading edge shaped.jpg (204.34 KiB) Viewed 10781 times
Rough cutting leading edges to flaps.jpg (245.07 KiB) Viewed 10781 times
Flap ready for install.jpg (202.56 KiB) Viewed 10781 times
I added some balsa block in the centre of the wing where the bolts will go through, just to help prevent any accidental over tightening causing damage during use.
Gluing support blocks in place.jpg (250.75 KiB) Viewed 10781 times
The phrase measure twice cut once is something I live by, which is good, as I was amazed to take not two, but three goes at calculating the position for the wing securing bolts. Must be the end of a long week...
Measure twice cut once.jpg (217.21 KiB) Viewed 10781 times
BMFA Examiner
Chris Bradbury
Postby Chris Bradbury » October 29th, 2018, 12:59 am
I glued the servo mounts in place before skinning the lower side of the wing.
Gluing servo supports in.jpg (236.23 KiB) Viewed 10780 times
Servo bay ready to be covered.jpg (228.15 KiB) Viewed 10780 times
Skinning the centre wing panel.
Lower wing skin sheets glued together.jpg (203.92 KiB) Viewed 10780 times
Gluing the lower wing skin on.jpg (224.57 KiB) Viewed 10780 times
BMFA Examiner
Chris Bradbury
Postby Chris Bradbury » October 29th, 2018, 1:09 am
With the wing skinned, I cut out some of the holes I need for servos and wiring. The centre hole is to allow wiring down in to the fuselage.
I also made a couple of tools for doing a couple of particular jobs, as it would seem I need to check Permagrit to add some more useful items to my list. In particular I made a small saw for cutting the servo bays neatly, which is a hacksaw blade with the pins knocked out and a small balsa handle added, which works really well for the job.
A couple of tools made for specific jobs.jpg (210.64 KiB) Viewed 10779 times
Servo hole cut.jpg (198.11 KiB) Viewed 10779 times
Bottom of the skinned wing.jpg (161.95 KiB) Viewed 10779 times
Bottom of the skinned wing with servo mounts in place.jpg (159.67 KiB) Viewed 10779 times
Centre hole in wing for wiring to access the fuselage.jpg (199.79 KiB) Viewed 10779 times
BMFA Examiner
Chris Bradbury
Postby Chris Bradbury » October 29th, 2018, 1:14 am
I'm using live hinges for all control surfaces, based on 3mm carbon rods.
Flap in max down position.jpg (213.4 KiB) Viewed 10779 times
Flaps fown.jpg (195.27 KiB) Viewed 10779 times
Flap hinges with small reinforced aluminium rings.jpg (206.88 KiB) Viewed 10779 times
Lower side of the wing showing the gap for flap operation.jpg (201.15 KiB) Viewed 10779 times
Lower of centre wing piece.jpg (166.08 KiB) Viewed 10779 times
Test fitting for leading edge.jpg (242.91 KiB) Viewed 10779 times
Checking flap movement clears the fuselage.jpg (216.59 KiB) Viewed 10779 times
Flap in max up position.jpg (189.05 KiB) Viewed 10779 times
BMFA Examiner
Chris Bradbury
Postby Chris Bradbury » October 29th, 2018, 1:21 am
The next small job was to add and shape a leading edge and finish the fit of the centre wing piece to the fuselage.
Leading edge fitted and rounded.jpg (173.34 KiB) Viewed 10779 times
Cebtre wing piece in place.jpg (188.85 KiB) Viewed 10779 times
Centre wing is a good fit.jpg (199.61 KiB) Viewed 10779 times
Centre wing piece almost ready for glassing.jpg (137.46 KiB) Viewed 10779 times
Servo plate in place.jpg (157.25 KiB) Viewed 10779 times
A third of the barn door in place.jpg (159.92 KiB) Viewed 10779 times
BMFA Examiner
Chris Bradbury
Postby Chris Bradbury » October 29th, 2018, 1:22 am
The last job today was to start adding the form shape for the rear of the wing, that will eventually form in to the shape of the rear of the main fuselage.
Blocking out for the back of the wing.jpg (188.22 KiB) Viewed 10779 times
Rear wing lump rough formed.jpg (205.07 KiB) Viewed 10779 times
BMFA Examiner
Chris Bradbury
Postby Chris Bradbury » October 31st, 2018, 12:41 am
This evening I added the control surfaces and servo mounts to the outer removable wing pieces, which will now need a little sanding off to finish.
Gluing servo mounts.jpg (511.94 KiB) Viewed 10713 times
More servo mouning points.JPG (525.31 KiB) Viewed 10713 times
Hinge detail.JPG (476.93 KiB) Viewed 10713 times
Hinge close up.JPG (398.31 KiB) Viewed 10713 times
Flap internal.jpg (524.27 KiB) Viewed 10713 times
Left wing ready for trimming.JPG (515.34 KiB) Viewed 10713 times
Centre and left wing piece.JPG (268.42 KiB) Viewed 10713 times
Full wing.JPG (386.41 KiB) Viewed 10713 times
Aileron up, flap down.JPG (322.1 KiB) Viewed 10713 times
BMFA Examiner
Chris Bradbury
Postby Chris Bradbury » October 31st, 2018, 12:42 am
There is loads of control throw available.
Loads of throw.JPG (338.19 KiB) Viewed 10713 times
Nice and straight.JPG (372.45 KiB) Viewed 10713 times
Right wing end.JPG (417.19 KiB) Viewed 10713 times
BMFA Examiner
Chris Bradbury
Postby Chris Bradbury » November 1st, 2018, 11:28 pm
Finishing the main wings today.
Lining flaps up to match size.JPG (352.2 KiB) Viewed 10676 times
Unilight on right wing.JPG (628 KiB) Viewed 10676 times
Unilight and mounting slot.JPG (327.11 KiB) Viewed 10676 times
Running wires through the wing frame.JPG (476.67 KiB) Viewed 10676 times
A little sanding to finish.JPG (341.84 KiB) Viewed 10676 times
Main wing nearing completion.JPG (330.07 KiB) Viewed 10676 times
A giant barn door.JPG (291.19 KiB) Viewed 10676 times
Weighing components.JPG (415.01 KiB) Viewed 10676 times
Quick assemble.JPG (434.19 KiB) Viewed 10676 times
Getting a sense of size.JPG (459.23 KiB) Viewed 10676 times
BMFA Examiner
Chris Bradbury
Postby Chris Bradbury » November 1st, 2018, 11:30 pm
Current weight for everything in the image is a little under 8kg, so I'm still hoping to get this in under 20kg.
BMFA Examiner
Chris Bradbury
Postby Chris Bradbury » June 6th, 2022, 5:00 pm
Due to health problems I will no longer be able to finish this model. So this is now for sale in the condition you see it in from the latest photos.
This is the wooden frame only, but I can also sell some glass cloth if anyone wants that as well to finish the project.
Looking for £350 ono.
Located in Telford, Shropshire, but can take it to the BMFA National Centre, or Weston Park / Cosford over the next month or so.
BMFA Examiner
Joshua Henderson
Postby Joshua Henderson » June 8th, 2022, 7:10 pm
Message sent
