CoG advice please - chipmunk
Postby richard armstrong » July 25th, 2017, 12:54 pm
hi all
need some advice before i make a change?
at present i have lead on the tail wheel and 25 grams under the rudder i want to remove the lead weight and replace it with a 4s 3000mah dead battery, just behind the wing on the existing battery plate, i know move the weight forward will have an effect, on CoG,
i wondering if shift the weight forward but increase the battery to compensate would be enough?
18057778_134216050453080_3626197873371143713_n - Copy.jpg (168.33 KiB) Viewed 11004 times
Re: CoG advice please - chipmunk
Postby Cary Bailey » July 25th, 2017, 1:19 pm
Richard, you want to add approximately 320grams of weight just behind the wing but effectively only removing 25g plus whatever weight you have on the tail? By my guessing you want to add somewhere in the region of say 200g actual weight onto the model? Why add weight when we all strive to keep the model as light as we can? I propose you either try and lose some weight at the front of the model, remember it is probably a rule of thumb ratio of about 4 to 1, so removing 100 grams of weight at the front will enable you to remove about 25g from the tailwheel! Can you remove some weight from the front?
And putting a "dead" battery into an aircraft just to add some weight to keep the CofG correct is probably not a good idea for the reason that the material that a Lipo is made of, can under certain conditions, ie a crash or even heavy landing, can damage the battery and potentially damage the plane. Why add a risk to your model by adding a battery that you have no intention to use?
Postby richard armstrong » July 25th, 2017, 1:42 pm
use of a battery is an option but can be replaced with lead block instead of battery,
originally this had 3 heavy nimh's packs in the one behind the wing was for lighting and a 6v c pack
no lead in nose the engine is a fuji 32cc, and is a brick makes very nose heavy without lead in tail
dilemma???????
or do i just leave it alone
Postby Cary Bailey » July 25th, 2017, 1:58 pm
Rich, if it flies OK then leave it alone & try to hide the lead in the tail somehow. If you can reduce some weight from the nose then even better to enable removing some from the tail!
Postby richard armstrong » July 25th, 2017, 2:11 pm
leaveing it alone for, now
need to think of a way of make a block for the tail with out doing damage to the formers
access hatch??????
Postby richard armstrong » July 25th, 2017, 2:12 pm
has anyone got a COG stand i could borrow at Elvington?
Postby Cary Bailey » July 25th, 2017, 2:19 pm
Rich, make your own!! Give me a call & I will tell you what to do!!
Postby richard armstrong » July 25th, 2017, 2:33 pm
Cary Bailey wrote:Rich, make your own!! Give me a call & I will tell you what to do!!
call you later
i have a design i just found basic but works
ric
chris-berry
Postby chris-berry » July 25th, 2017, 5:42 pm
Richard, Steve flew it for you at Catton after I chickened out and it flew well.
It flew well with little need to change anything, so leave it alone. If it flies, then let it fly and don't mess with things and make sure the lead is secure and cannot ever come off. If you've got a dead battery then either keep it for sizing in other models, or to use as a weight when gluing or just throw it away.
Postby Cary Bailey » July 26th, 2017, 3:11 pm
Rich, I agree with CB!
Postby richard armstrong » July 26th, 2017, 3:48 pm
Cary Bailey wrote:Rich, I agree with CB!
i leaving it alone and sort it in winter
chris-berry
Postby chris-berry » July 26th, 2017, 5:48 pm
Richard, it doesn't matter what season it is. It doesn't need sorting. Just fly it and only mess with it if anything changes don't mess with it for the sake of it.
Postby richard armstrong » July 27th, 2017, 7:50 am
chris, point taken
Jack Kennedy
Postby Jack Kennedy » August 25th, 2017, 1:06 pm
Richard, is'nt that the same plane Steve flew for you at East Kirkby at the start of the year, if so, I was standing next to steve with Mike,and the plane flew great, ( thats down to the pilot ).
I would agree with the rest of the guys, as we say in my neck of the woods, ( if it's not broke don't fix it. )
needless to say, the guys who have given you very good advice, are in my opinion, talking to a brick wall
(You will mess with it )
The only way is up
Postby richard armstrong » August 25th, 2017, 6:19 pm
I HAVE TAKEN THE ADVICE AND LEFT IT ALONE
THANKS JACK
NOT SURE WHAT'S UP with some of the crowd because its that time in the year to have a go at Richard
enough thanks
Last edited by richard armstrong on August 28th, 2017, 1:50 pm, edited 1 time in total.
Jack Kennedy
Postby Jack Kennedy » August 28th, 2017, 1:37 pm
Richard, if you look at the start of your post, you were asking for advice, the crown, sorry, crowd, you are talking about have probably been doing this a lot longer than you or me, you seem to be taking things to personal.
Take the advice and move on
The only way is up
