Prop bolting orientation
Frank Skilbeck
Postby Frank Skilbeck » January 19th, 2018, 8:45 am
Sorry if this is covered elsewhere, just using my first multi-bolt prop (4 bolt on a DLA 32) with a wooden prop, is there a preferred bolt layout, should the holes be at 45 deg to the prop blades or 0/90 degrees. I looked on line and could find pictures of both, so thought I would ask.
paul hughes
Re: Prop bolting orientation
Postby paul hughes » January 19th, 2018, 12:05 pm
Frank, I think it depends on the engine, remember that when the magnet is passing the hall sensor the prop should point to 1 o'clock. this will determine the hole position on the prop hub. not very scientific but it might help.
Frank Skilbeck
Postby Frank Skilbeck » January 19th, 2018, 6:59 pm
Paul, thanks for that, so it's basically position the prop for hand starting, much appreciated.
