wheel axles advice please
Postby richard armstrong » January 25th, 2018, 8:42 pm
wheel axles for 25kg model DH Beaver
i have 6 in wheels need to be mount on a fibreglass under-cart must be able to take up to 25kg
what would the best material to make a wheel axle?
mild steel rod
hardened tool rod
aircraft grade Ali rod
axle idea made on my lathe
advice and suggestions welcomed
Re: wheel axles advice please
Postby Alan Cantwell 1131 » January 25th, 2018, 8:55 pm
High tensile cap head bolt,
Postby richard armstrong » January 25th, 2018, 9:04 pm
Alan Cantwell 1131 wrote:High tensile cap head bolt,
thanks didn't thing of that
would M6 or my 8m be to big?
Postby richard armstrong » January 26th, 2018, 8:02 pm
Alan
what metal rating for steel to heat treat?
would like to have a go at turning and heat treating the axles
would a stand high tensile steel do? 12mm round bar to turn the axles?
i finding metel turning very therapeutic
arthur barlow
Postby arthur barlow » January 26th, 2018, 8:25 pm
High tensile m8 more than man enough fibre glass will snap before the Bolt
Postby richard armstrong » January 26th, 2018, 8:38 pm
arthur barlow wrote:High tensile m8 more than man enough fibre glass will snap before the Bolt
thnks arther
i will look m8 cap bolts
arthur barlow
Postby arthur barlow » January 26th, 2018, 8:55 pm
EBay 161214378076 you need to measure the whith of the wheel and mounting point of the undercarriage you want the unthread bit in the wheel
Postby Alan Cantwell 1131 » January 26th, 2018, 9:39 pm
Richard, just buy high tensile bolts, and turn the axles from them, metal turning therapeutic eh? Not when you do it for a job,
Postby richard armstrong » January 26th, 2018, 11:33 pm
brought the m8 bolts
thanks all
