Side/Down thrust
Jack Kennedy
Side/Down thrust
Postby Jack Kennedy » February 5th, 2018, 6:00 pm
Was just wondering, Miles Magister 85" is there any side or down thrust, came across a 52" plan that shows 2 - 3 degrees of side thrust, but no down thrust, have everything set to zero at the moment.
would be gratefull for any assistance.
( if nothing else to keep me right )
Jack
The only way is up
arthur barlow
Re: Side/Down thrust
Postby arthur barlow » February 5th, 2018, 6:42 pm
Test fly it and see what happens
Postby DAVE JOHNSON » February 5th, 2018, 7:09 pm
You just want the crash bits Arthur---we know your game !!
arthur barlow
Postby arthur barlow » February 5th, 2018, 8:38 pm
Not always I have 3 to test crash
Postby Cary Bailey » February 6th, 2018, 11:57 am
Jack, play safe & build in 2 degrees side and 2 degrees down thrust, this is pretty much a starting point. If the model experiences the need for lots of up trim on the elevator you can always reduce the down thrust but as the motor increases power you will experience a tendency for the aircraft to climb excessively if there is no down trim hence usually a small amount of down thrust is applied.
Jack Kennedy
Postby Jack Kennedy » February 6th, 2018, 1:31 pm
Thanks Cary, as a rule of thumb I would have thought 1 - 2 degrees of side/down, I would'nt have thought it would have differed from plan to plan as the 52" explained, thanks anyway will work on that basis.
I must say Dave, Arthur never misses a chance
Arthur this plane would be no good to you anyway, there is no gaffer tape and lolly sticks on it. :lol: :lol:
Jack
The only way is up
Postby Cary Bailey » February 6th, 2018, 2:15 pm
Jack, Arthur treats any plane as being a bundle of sticks with a motor strapped on the front! That's how he flies most things anyway.....
Users browsing this forum: No registered users and 49 guests
