P47 access hatch
P47 access hatch
Postby richard armstrong » March 17th, 2018, 6:22 pm
need advice
the p47 has no top access for internals
my query
is it possible to cut a top hatch that includes the canopy without messing up the fuse integrity
or would it be better to cut a small side hatch for power switches and air fill
20171015_175820 - Copy.jpg (165.71 KiB) Viewed 10781 times
Re: P47 access hatch
Postby Phil Clark » March 17th, 2018, 7:51 pm
Small hatch Richard......a large upper hatch incorporating canopy will cut through the upper main fuselage longerons, so is to be avoided.
Postby richard armstrong » March 17th, 2018, 9:02 pm
Phil Clark wrote:Small hatch Richard......a large upper hatch incorporating canopy will cut through the upper main fuselage longerons, so is to be avoided.
thanks phil
small side hatch it is
Postby Alan Cantwell 1131 » March 18th, 2018, 10:43 am
Does it need one? There’s a big hole underneath we’re the wing sits?
Postby richard armstrong » March 18th, 2018, 11:18 am
Alan Cantwell 1131 wrote:Does it need one? There’s a big hole underneath we’re the wing sits?
at present all switch are accessed via the wing removal not the best for shutting the aircraft down.
an airframe with clean lines, a recessed hatch is in order as it has to hide the FRS duel redundancy switch, ign light and switch and air fill
Postby Alan Cantwell 1131 » March 18th, 2018, 9:34 pm
Ah, got it, what you need is a hatch,
Charlie Cox
Postby Charlie Cox » March 19th, 2018, 6:03 pm
Sliding canopy perhaps.
Charlie
Postby richard armstrong » March 19th, 2018, 7:24 pm
Charlie Cox wrote:Sliding canopy perhaps.
Charlie
ooo thanks for that
a possibility i will see if it possible depends on how well the canopy is glued down,
but the small hatch is number one on leader board for now
Postby Phil Clark » March 22nd, 2018, 8:56 pm
Something as simple as this is all you need Richard.........small hatch just big enough to access what's inside, hinged with small plastic off-set hinges, held shut with neodym magnets.
Postby richard armstrong » March 22nd, 2018, 9:17 pm
Phill that what i had in mind thanks for the photos
best place to put the hatch?
is that thin ali with a backing
Postby Phil Clark » March 23rd, 2018, 9:29 pm
Lithoplate with a section of the models balsa skin bonded on the back.
Location wise.......get yourself a good P-47 3-view set of drawings & find a convenient sized/located hatch on the forward fuselage........if you're going to add a functional hatch, you may as well put one in a scale location.
......you'll find there are several suitable options on the port side of a P-47!!!
Postby richard armstrong » March 23rd, 2018, 10:03 pm
Phil Clark wrote:Lithoplate with a section of the models balsa skin bonded on the back.
thanks phil see you sunday
