Glen Torrance 1/3 scale Fokker DVI
Postby Cary Bailey » March 19th, 2018, 12:13 pm
Glen Torrance 1/3 scale Fokker DVI available for sale. Fitted with ZDZ 100 opposite twin motor, all servos, all electrics renewed, new ignition 300Ma Nimh battery, new fuel system incl fuel tank, tank mounting tray, fuel tubing, carb serviced, new 32x10 Falcon prop, all joints around fuselage and wing inspected and re-done where necessary & new undercarriage axle installed.
The aircraft is ready for re-test flying, just needs receiver, battery and fuel (obviously) to fly. The model was built by Matt Harrowven and was not subject to the 20Kg inspection/exemption.
Offered for sale at £1450 or very near offer.
Pictures available upon request
Contact me through the LMA site for further information
Thankyou
ian redshaw
Re: Glen Torrance 1/3 scale Fokker DVI
Postby ian redshaw » March 22nd, 2018, 1:37 pm
Cary, your wording is a little confusing to say the least and might be putting off any potential buyers! It doesn't require an over 20kg exemption, inspection or whatever as it isn't over 20kg! Has your reworking taken it over then? If so, the model is now set up so with the addition of another Rx and battery supply it is fully compliant with a servo on each surface etc. That said though, I'd be very surprised if whatever you have done to it would take it over 20kg anyway. It's an awesome model to fly with bags of power available if needed, landings need a bit of care and till the new owner learns its quirks, tail up wheeler landings would be recommended. A funky model, very rarely modelled and a refreshing change from the DVII and DrI that we see regularly.
Hope this helps, Ian.
