Models & ancillaries for sale
David Middleton
Postby David Middleton » April 8th, 2018, 4:04 pm
Hello All
Due to ill health I am having to give up my modelling activities so the following items are for sale.
Glen’s Extra 78
Rx Futaba R608RS Rx2
Rx Battery Overlander AF 6 V
Ignition Battery Eneloop 6 V
Elevator servos Futaba S3010 x2
Rudder servo Hitec HS-645MG
Aileron servos Hitec HS-645MG
Throttle servo Futaba S148
Choke Futaba S9301/2X
Engine ZDZ 56 RV-J
Weight 6.4 kg (14 lbs 2 ozs)
Initially flown on a Zenoah G 38 which was replaced with a new ZDZ 56 RV-J after a few flights it was shaping up well when my health issues caught up with me.
Complete and ready to go £400, airframe only £150.
Glen’s Extra 68
Rx Futaba R617FS Rx5
Rx Battery Eneloop 6 V
Ignition Battery 3.6 V
Elevators Futaba S3001
Throttle Futaba S3001
Ailerons Futaba S3010/
Rudder Hitec HS-645MG
Engine Zenoah ZG 20
or Equivalent electric motor and ESC
Weight 4.68 Kg (10 lbs 5 ozs)
Mostly flown on the ZG 20 but was quite successful on the electric motor. It’s an OMA-5025-375 with a Turnigy Sentilon 100A HV ESC
Complete and ready to go with both motors £300, £50 less without electric. Airframe only £100.
25% Fournier RF4D
Partly built (basic fuselage box only) from the Mick Reeves kit. Includes retract, cowl, canopy and all moulded fairings. At £80 it’s about £100 saving on new.
Something On The Small Side
e-Flight Taylorcraft
Rx Futaba R617FS Rx6
Elevators MPX Tiny-S
Rudder MPX Tiny-S
Throttle Speed Controller
Ailerons SMS7.5
Weight 1.08 Kg (2 lbs 7 ozs)
Somewhat overpowered as the power chain was taken from an aerobatic model. Three cell 2700mAh LiPo battery is an unusual fit so included in the package.
Looking for around £90.
Acro Wot Foamy
Weight 1.16 Kg (2 lbs 9 ozs)
It’s an Acro Wot - what more is there to say. £75.Could include a battery if required.
Other Things
Lipro Plus Four channel balancer/charger with a modest selection of charge and balance leads £50.
12 volt 50 amp battery £20.
Servos
Hitec HS-645MG £10 each, five for £40
Futaba S9202, S9204, S9310, S136G (Retract) one of each £10 each. £30 the lot.
Futaba S3010 very little used £8 each, £40 for 5.
Futaba S3001 and S148 £5 each. five for £20
Also a selection of output discs, arms and extension leads for all, prices by negotiation but low.
And Finally
My well used and much loved ZG74 complete with easy start unit. Although it’s 20 years old it’s in good condition so I’m asking around £200.
I am in the Scottish Borders and can be contacted via this forum or on 07795 310684.
pete farrington
Re: Models & ancillaries for sale
Postby pete farrington » April 8th, 2018, 6:10 pm
Hi I would like 5 hitec 645 servos . Thanks pete
David Middleton
Postby David Middleton » April 8th, 2018, 7:49 pm
Hi Pete
I've had a couple of other enquires via text. It will take a little while to figure out which ones I can meet. Will try and get back to you tomorrow.
David
David Middleton
Postby David Middleton » April 9th, 2018, 8:18 pm
Hi Andrew
Could send me your email contact details to rorymac56@gmail.com so we can keep in touch direct rather than via the forum.
David
David Middleton
Postby David Middleton » April 9th, 2018, 8:39 pm
Think I've got myself into a bit of a knot on this post. Will start again from the beginning tomorrow.
