Pipe
Stuart Solomon
Pipe
Postby Stuart Solomon » June 2nd, 2018, 10:26 am
Can anyone help, I need a piece of 1" dia pipe with a sharp bend. Could be ally or steel about 1.5 or 2mm wall thickness.
Steve Perry
Re: Pipe
Postby Steve Perry » June 2nd, 2018, 11:30 am
Have you thought about copper, the outside of 22mm fittings is about an inch.
We have all sorts of bending equipment at work, but that small bend radius on the inside makes it very difficult as the back of the bend has to stretch a lot and the inside of the bend tends to squash.
Could you do a 45 degree miter ?
Glenn Masters
Re: Pipe
Postby Glenn Masters » June 2nd, 2018, 5:24 pm
Check out the local diy store for wall mounted grab handles that aid getting in or out of the bath etc. They are usually steel albeit white painted - you get 2 bends for the price of one !. . . and if they're no good for the model, you might fit them over your bath - useful now you're gettin on a bit . . . .
Stuart Solomon
Re: Pipe
Postby Stuart Solomon » June 2nd, 2018, 5:27 pm
Thanks for that Glenn, dont forget who taught you to fly a certain profile model. :-)
paul hughes
Re: Pipe
Postby paul hughes » June 2nd, 2018, 6:48 pm
Hi Stuart, If you have the pipe you can cut at 45 deg and weld or solder. I have some off cuts from 1" wing tube if it helps.
Stuart Solomon
Re: Pipe
Postby Stuart Solomon » June 4th, 2018, 10:56 am
Thanks chaps, think it's sorted now. Just gonna develop it from stainless sheet.
