Composite QQ Yak 54 2.6m ARF BNIB "now reduced"
martinfairchild
Postby martinfairchild » June 16th, 2018, 8:35 am
Composite QQ Yak 54 2.6m ARF BNIB.
2 boxes, wings in one the rest in the other, all BNIB never removed by me, just inspected by Dan @ KLMS prior to collection by me.
Key Features
Designed by Quique Somenzini, the Composite QQ Yak 54 2.6m is an updated version of his Yak 54 he became famous for
All-composite construction provides a light and strong airframe to suit the demads of modern unlimited pilots
Center-pivot hinges allow extreme control deflections and quiet operation
Engine soft mount reduces vibration, noise and fatigue to the airframe
Painted-in-the-mold 3-color scheme designed by Mirco Pecorari of Aircraft Studio Design
Easy access and installation of canisters, tuned pipes or standard mufflers
Engine dome provides convenient access to throttle servo and electronic ignition
Designed around the DA 100-120cc gas engines
High-quality hardware and control linkage geometry designed for maximum deflection of control surfaces
Needed To Complete
- 8+ channel transmitter and receiver radio system
- (7) high-voltage, high-torque servos; (1) high-voltage, high-speed servo
- 100–125cc 2-stroke gas (petrol) engine
- Propeller
- Spinner
- Ignition battery pack
- Receiver battery pack
SPECS
Approximate Assembly Time: 20+ Hours
Control Throw (Ailerons): Low: 70mm up/down at root, 40% expo; High: 140mm up/down at root, 65% expo
Control Throw (Elevator): Low: 15mm up/down at counter-balance, 20% expo; High: 95mm up/down at counter-balance, 40% expo
Control Throw (Rudder): Low: 50mm right/left at counter-balance, 5% expo; High: 120mm right/left at counter-balance, 45% expo
Flying Weight: 28–29 lb (12.7–13.2kg)
Main Wing Tube Length: 31.5 in (800mm)
Main Wing Tube OD: 1.57 in (40mm)
Recommended Fuel: Gasoline
Recommended Receiver Battery: (2) 2S 4000mAh LiPo receiver pack
Spinner Size: 4.5 in (114mm) P-51-style, soli back plate
Tail Wing Tube Length: 15.75 in (400mm),15.75 in (400mm)
Tail Wing Tube OD: 0.472 in (12mm)
Wing Loading: 32.3 oz/sq ft (98.6 g/sq dm)
Wingspan: 102 in (2600mm)
You would be very lucky to find another one of these available BNIB.
Also advertised elsewhere.
Will not remove from box to take picture, the generic pictures are what you get.
Cash on collection only, but would be willing to meet on the proviso a none refundable deposit is paid up-front and my fuel costs are covered.
Questions, text or call Martin on 07960410340
£1000.00
