Sky-120 by Tony Nijhuis
Lynne Roberts
Re: Sky-120 by Tony Nijhuis
Postby Lynne Roberts » July 2nd, 2018, 8:04 am
Geoff, your membership card is in the post.
Postby Bob Thompson1894 » July 2nd, 2018, 2:44 pm
Dave Parry wrote:Hi Bob, it sits in your outbox until it is picked up by the person you have sent it to, its your indicator that they have read it or not as the case is at the moment.
Thanks Dave. Didnt realise that.
Geoff McVey
Postby Geoff McVey » July 2nd, 2018, 5:11 pm
Lynne Roberts wrote:Geoff, your membership card is in the post.
Thank you.
Geoff McVey
Postby Geoff McVey » July 4th, 2018, 5:48 pm
Hi Lynne,
LMA membership card and members handbook came through the post yesterday.
Thank you.
Mike Ellis
Postby Mike Ellis » July 5th, 2018, 7:35 am
Ah the dreaded PM strikes again lol
Use an email instead!!! THAT WORKS !!!!!!!
Geoff McVey
Postby Geoff McVey » July 5th, 2018, 7:02 pm
Hope this is not a dumb question, the recommended engine for the Sky-120 is the Zenoah 38cc, the Zenoah G380PU 38cc Rear Exhaust Aero Engine, are these 2 both the same or are they slightly different.
Many thanks.
Steve Mansell
Postby Steve Mansell » July 5th, 2018, 8:54 pm
The same.
I've had three z38's and a z45. Rock solid engines, and will turn large props with ease.
Geoff McVey
Postby Geoff McVey » July 5th, 2018, 10:23 pm
Steve Mansell wrote:The same. I've had three z38's and a z45. Rock solid engines, and will turn large props with ease.
Hi Steve,
Many thanks, what prop would you use for the Sky-120 / Zenoah G380PU 38cc Rear Exhaust Aero Engine.
Geoff
Steve Mansell
Postby Steve Mansell » July 6th, 2018, 12:26 am
Geoff, I ran 20*8 for the first few tanks, and a 22*8 on my fokker dvii.
If you're getting back into flying after a bit of a lay off I'd keep to a low pitch as initial acceleration is better, and for a plane like the sky 120 you're not looking for speed.
The original silencer is not much good as it vents through slots on the rear face. I silver soldered them closed, and silver soldered two pipe outlets on instead. There are after market "pitts style" exhausts available from most of the model engine suppliers that do a better job!
Steve Mansell
Postby Steve Mansell » July 6th, 2018, 10:49 pm
Geoff,
Correction, looking at my notes I started with 18*8, and after a few tanks went up to 20*8. I got mixed up with the props I used on the z45.
Mike Ellis
Postby Mike Ellis » July 8th, 2018, 5:13 am
Been using ZG38s since 1991 and always have one in my collection. Great engine, once primed usually starts within 2 flicks, never had one miss a beat ever !!
Oh yes and we know the silencer needs to be silver soldered together after removing the plate inside and also solder the slots up on it also.
Even better, make one of Sid kings designs and make it sound like a Rolls Royce !!
Enjoy!!
Geoff McVey
Postby Geoff McVey » July 8th, 2018, 3:58 pm
Steve Mansell wrote:Correction, looking at my notes I started with 18*8, and after a few tanks went up to 20*8. I got mixed up with the props I used on the z45.
Hi Steve,
Will take your advive and use what you have done, where is the best place to buy props of this size, wooden or any other type of material.
Geoff
Geoff McVey
Postby Geoff McVey » July 8th, 2018, 4:01 pm
Mike Ellis wrote:Been using ZG38s since 1991 and always have one in my collection. Great engine, once primed usually starts within 2 flicks, never had one miss a beat ever !!
Hi Mike,
Once I have bought the Zenoah G380PU 38cc Rear Exhaust Aero Engine, where would the best place to get the silencer silver soldered together after removing the plate inside.
Geoff
Mike Ellis
Postby Mike Ellis » July 8th, 2018, 4:32 pm
You can do it yourself. First of all with the silencer apart,
Gently flatten the slots with a hammer. Clean the flattened slots and the edges where the silencer fits together with steel wool. Now you will need a butane torch , some borax powder to make a flux, and a silver soldering rod ( low melting point) about 2 mm thick. Place the assembly together on a firebrick, brush the flux on and heT it up holding the rod close to it. The correct heat the solder will melt and capillary(run) into the joint and seal it. I’m sure you must know a modeller etc who would help you also. Cleanliness is the key !! If it’s not clean it won’t solder !!
Mike Ellis
Postby Mike Ellis » July 8th, 2018, 5:00 pm
Also remember you have to then drill the soldered exhaust box and fit 2 outlet pipes to it.
Steve Perry
Postby Steve Perry » July 8th, 2018, 7:16 pm
The Prop Guy http://www.propguy.co.uk/ or from his stand at LMA shows :)
Steve Mansell
Postby Steve Mansell » July 8th, 2018, 7:33 pm
I second that, Prop Guy only sells quality goods. He also sells protective sleeves for props. I have recently bought four large ww1 for a large electric that I'm building, and all are perfectly balanced.
Geoff McVey
Postby Geoff McVey » July 9th, 2018, 2:36 pm
Hi Steve,
Many thanks for the weblink to Prop Guy.
Geoff
Geoff McVey
Postby Geoff McVey » July 9th, 2018, 2:41 pm
Picked up the Sky-120 kit from Slec this morning, they could not have been more helpful, had time to look around the factory, and have never seen so much balsa wood, yes it's a big box.
Building board is almost finished, 24" x 78" more than big enough at the moment, slowly getting all the building tools, glues etc, hopefully start building in a few days time and start a build thread :)
Postby Dave Parry » July 9th, 2018, 6:14 pm
Can I also recommend Fighter Aces, and Kings Lynn for props as they do 20x8 Menz props which I find are great at a good price.
