Copying Plans
Eric Shepherd
Copying Plans
Postby Eric Shepherd » August 28th, 2018, 1:38 pm
I've just bought the Top Flite Stinson Reliant kit which will be electric powered. I don't want to use the original plans to build from as the have to be cut up, & have been looking for someplace to get copies. It appears things have changed since I last did this, scanners to scan a document 91cm wide are few & far between so it seems. All the firms I've tried can only do up to AO size. Then I thought I'd had a brain wave as I also have a copy of TF's PDF file which has copies of the plan in it &[img][img][/img][/img] I can blow up to 800% on my PC & it's still readable. Has anyone had this done or know a company who can do it without charging an arm & a leg.
Cheers Eric.
Eric Shepherd
Re: Copying Plans
Postby Eric Shepherd » August 28th, 2018, 3:45 pm
Managed to find a local print shop who knew what I was talking about, got it done £10 a copy, good quality paper.
http://www.replica-print.co.uk/
Return to “Electric Stuff”
