My brain hurts!
Steve Mansell
My brain hurts!
Postby Steve Mansell » September 15th, 2018, 1:32 pm
If I have a set of 1/6 scale plans, but require 1/4 scale, how do I work out what percentage increase I need to tell the print shop?
I'm not to bad on excel, but need a formula.
One for all you maths wizards!
Mike Ellis
Re: My brain hurts!
Postby Mike Ellis » September 15th, 2018, 2:37 pm
Not being any good at maths either, how about finding out the span, length etc of the full size one you are modelling.
Once you know that, devide by 4 and thats 1/4 scale !!
steven patey
Re: My brain hurts!
Postby steven patey » September 15th, 2018, 3:22 pm
https://www.instructables.com/id/Copier ... one-Right/ the general principle is explained here.
Steven
Mike Ellis
Re: My brain hurts!
Postby Mike Ellis » September 15th, 2018, 4:34 pm
Nope !! Didnt get any of that lol
Surely if you want something of a measured size to fit into a space of another known size, hat principle works, BUT if you need to know what 25% of a KNOWN size is then it dosent!
Eg: full size = 36 feet (span) so 25% = 9 feet.
So tell the printer who will print your plan, that you wish the plan supplird to them,that measures 6 feet (1/6 full size) needs to be enlarged to 9 feet !! Thats what I tell the people who print for me and it always works lol
maurice northcott
Re: My brain hurts!
Postby maurice northcott » September 15th, 2018, 5:06 pm
I always take 100 divide the the scale you have, ie in this case 6 = 16.6666667
Now take 100 divide by the scale you want, ie in this case 4 = 25
Then divide the 25 by 16.6666667 = 1.5
So you want your 1/6 drawing enlarged by 1.5 OR (in other words) you want it enlarged 150%
Simples :-)
Mike Ellis
Re: My brain hurts!
Postby Mike Ellis » September 15th, 2018, 5:09 pm
Now even I can understand that !! Well done Maurice!!
Simples!!
maurice northcott
Re: My brain hurts!
Postby maurice northcott » September 15th, 2018, 5:17 pm
Always bear on mind you must check:
(a) Is the original plan correct or has it shrunk or stretched in the printing process?
(b) Is the enlarged plan the correct size? Calculate what a couple of key dimensions are (eg length and width)before you leave home, take your rule of choice with you (inches or mm) and check the enlarged drawing before you leave the shop. You may need to make "slight" adjustment when you get home, but how much "adjustment" is acceptable to you is personal choice.
Good Luck matey :-)
David Baker
Re: My brain hurts!
Postby David Baker » September 15th, 2018, 6:30 pm
Usually work from 1/72 scale 3 views of the original aircraft... which is really useful as it also makes it easy to scale things up from a 1/72 scale Airfix kit..
just get your “multiply by number” and you have a 3D reference
Steve Mansell
Re: My brain hurts!
Postby Steve Mansell » September 15th, 2018, 7:33 pm
Magic!
Thanks all.
I can do a small spread sheet with Maurice's calcs, so I will just need to input the original scale and required scale and viola! off to the printers.
Ta very much
ian redshaw
Re: My brain hurts!
Postby ian redshaw » September 16th, 2018, 9:33 am
Before you get the plan copied, draw two lines at 90 degrees to each other, on each sheet. I draw the lines to a length that once enlarged come to a known measurement and write "these lines to measure 500mm on the finished enlargement". This saves any hassle when you pick them up, it also gives the operator chance to get them spot on without the customer being present, making it a much more pleasurable task for them.
Ian.
Steve Mansell
Re: My brain hurts!
Postby Steve Mansell » September 16th, 2018, 3:31 pm
Thanks for the tips.
Still undecided on subject, but will be an early WW1.
It will be a linen covered fuselage, as I have just finished an Albatros C.iii, and the ply covering meant a lot more lead up front than I wanted. (It also cost a fortune!)
Thanks all again,
Users browsing this forum: No registered users and 71 guests
