Side mounted G62 silencer for in-cowl. Cost new £148.99. £50.00inc post. OVNO Sidemounted silencer for the ZG 62 with
Nigel I'Anson
Postby Nigel I'Anson » November 1st, 2018, 8:49 am
Toni clark Side mounted G62 Silencer only a hours use
DSC_0003 (Large) (4).JPG (221.08 KiB) Viewed 2193 times
Side mounted G62 silencer for in-cowl. Cost new £148.99. £50.00 inc post. OVNO
Sidemounted silencer for the ZG 62 with the Piper HMS. This silencer can be used when it is impossible to use the type fitted behind the crankcase. This sidemounted layout is far from ideal dynamically and shows up in the tickover speeds as excessive movement. With the engine rigidly fixed there is no problem.
To use this silencer without the Hydro-Mount-System, you either use the motor mount #6714 or you will have to fit a piece of 1 mm thick metal plate between the engine and the motor mount #6590, #6561 or #6562, extend this plate to take the rear fixing lug on the silencer.
Weight 295?g.
Call Nigel on 07917854421
DSC_0007 (Large) (2).JPG (210.24 KiB) Viewed 2193 times
DSC_0006 (Large) (3).JPG (218.07 KiB) Viewed 2193 times
DSC_0005 (Large).JPG (235.42 KiB) Viewed 2193 times
