Carbon wing tube and sleeve
Dave Osborne
Postby Dave Osborne » December 1st, 2018, 9:21 pm
Does anyone know where to buy a carbon wing tube and matched sleeve in the UK? I want one around 35 - 40mm diameter but I cannot find a UK supplier on the web. Plenty of aluminium and phenolic ones but not carbon. I could make my own outer but would rather buy one.
cheers Dave.
Ken Roddham
Re: Carbon wing tube and sleeve
Postby Ken Roddham » December 1st, 2018, 10:07 pm
I've used this company in the past for carbon fibre sheet and had good service.
http://www.easycomposites.co.uk/#!/cure ... e-products
They should be able to assist with wing tube material.
Ken
Dave Osborne
Postby Dave Osborne » December 2nd, 2018, 11:44 am
Thanks Ken.
I know Easy Composites well. They do plenty of suitable carbon tube for the actual joiner. Its the outer tube thats the problem. It only needs to be a thin walled fibreglass material. The carbon tubes from Easy composites will nest OK, but using another carbon tube for the outer is overkill. As I said I can make one but would rather buy one. There are plenty of sources in the US but the postage to the Uk is prohibitive.
Cheers Dave.
Steve Mansell
Postby Steve Mansell » December 2nd, 2018, 2:19 pm
Dave,
https://www.carbonfibreprofiles.com/ind ... gs7f21htg3
I haven't used these people yet, but will be soon for my next build.
Nigel Cox
Postby Nigel Cox » December 2nd, 2018, 6:30 pm
https://www.bucks-composites.com/ but they only do CF tubes
Dave Wilshere
Postby Dave Wilshere » December 3rd, 2018, 9:09 pm
Iain at IAD is your man. does exactly what you are asking for
Dave W
Users browsing this forum: No registered users and 54 guests
