smoke nipple advice
smoke nipple advice
Postby richard armstrong » January 23rd, 2019, 10:44 pm
before i start taking a drill to a very expensive header and can
50cc header to cannister set up
been ask to install smoke tank and pump to edge 540, no nipple up at the header
where is the best place to place nipple & how far off the header does the smoke nipple have to be ?
s shape header to cannister photo will follow
Pat Cuss
Re: smoke nipple advice
Postby Pat Cuss » January 24th, 2019, 10:00 am
Place the nipple 20 to 25mm from the cylinder exhaust flange and drill a .5mm hole, this will give you good smoke, with smoke fluid or diesel slightly thinned with paraffin. If you need more smoke or your pump is not very powerful go to .75mm hole. smoke works best from half to full throttle only, and don't forget the one way valve to stop the tank being emptied via the vent. The tank should be set up the same as the petrol tank = clunk, feed, fill and vent with fill plugged when flying. # I make my preferred system with a1.5 mm hole in the exhaust nipple flattened out to spread the fluid spray and then control the fluid flow with a 'slug' in the fuel line drilled with the .5mm hole. back from this is the one way valve, then a screen washer pump, then the micro switch operated from the arm of a servo. Simple but fool proof. Run the pump on 6 to 7.2 volts. HM government warning Smoking is Hazardous to Health.
Postby richard armstrong » January 24th, 2019, 2:54 pm
the pump is a variable Sullivan Skywriter Smoke Pump
tank is a dubro fitted as petrol tank
was thinking usiing this
http://the-mt-shop.co.uk/product_info.p ... cts_id=402
http://the-mt-shop.co.uk/product_info.p ... cts_id=119
Postby richard armstrong » January 28th, 2019, 5:11 pm
this is the set up but not drilled yet
best place for nipple?
using a just engine smoke nipple
Dave Wilshere
Postby Dave Wilshere » January 28th, 2019, 8:30 pm
You cannot put a smoke nipple that close to the flange on a canister set up, it will suck fluid into the engine, foul the plug and reduce power. On the Zimmermann set up you have its designed to have the smoke nipple in the canister inlet tube, just in front of the canister body. Either way you cannot tap the 0.5mm thick stainless tube, it will need a bulkhead fitting or as designed brazed in tube.
Postby richard armstrong » January 28th, 2019, 9:03 pm
i did plan on sliver solder the nipple as a precaution.
please can you point me to the correct nipple and mark on the photo where the nipple needs to be put if you need more photos let me know i will email you them.
u can call me if you wish
Postby richard armstrong » January 28th, 2019, 11:40 pm
is this what you had in mind drill, tap and solder a nipple in a similar position
Postby richard armstrong » January 28th, 2019, 11:50 pm
or this set up
or put is half way down on s bend at joint?
one way no return check valve in place on black line
Pat Cuss
Postby Pat Cuss » January 29th, 2019, 9:04 am
Report this post
Quote
Postby Dave Wilshere » January 28th, 2019, 11:30 pm
Good point, when using a tuned canister the back pressure is probably greater. I tend to make my own silencers and I link the smoke switch to the throttle position so it only operates from half throttle upwards. I have not experienced any problems as you describe, probably due to my crummy silencer design. I always silver solder a m4 nut on the exhaust pipe and use a piece of threaded rod with a locknut to be able to drill the entry hole in.
Postby richard armstrong » January 29th, 2019, 10:01 pm
sorry to be a pain but i am a little confused on where to drill and solder the nipple?
Postby Bob Thompson1894 » January 30th, 2019, 8:16 am
as above- "just in front of the canister body."
Postby richard armstrong » January 30th, 2019, 9:48 am
Bob Thompson1894 wrote:as above- "just in front of the canister body."
you mean like this but with nipple
Postby richard armstrong » January 30th, 2019, 9:51 am
how hot does the oil have to be to vaporise
using MT oil
Postby Bob Thompson1894 » January 30th, 2019, 10:46 am
I was simply quoting the excellent advice given to you by Dave Wilshire above. I suggest you read that carefully.
Postby richard armstrong » January 30th, 2019, 11:11 am
thanks bob
the exhaust is a custom made and cost over £250 so i want to make sure that i do it correct its a one shot deal so i cannot afford to fuc it up
paul hughes
Postby paul hughes » January 30th, 2019, 12:11 pm
mountain and molehill springs to mind.
Postby richard armstrong » January 30th, 2019, 3:25 pm
sorted decision made and client happy
Glenn Masters
Postby Glenn Masters » January 30th, 2019, 3:57 pm
Client ?
Postby richard armstrong » January 30th, 2019, 5:17 pm
Glenn Masters wrote:Client ?
a mate who need help and is paying for parts upgrade
Postby Rob Buckley » January 30th, 2019, 7:20 pm
So how much are the folk who told you how to do it getting as their share?
