would like to ask if it is possible to switch the choke lever to the opposite side of the carb
i have a throttle lever and choke lever on the same side which are clashing could i reverse the choke lever?
Rob Buckley wrote:Turn the carb round so they are on the other side
ian redshaw wrote:It'd be easier to turn the engine Rob?
Rob Buckley wrote:ian redshaw wrote:It'd be easier to turn the engine Rob?
I don't believe Walbro would send a carb out of the factory with the throttle & choke levers clashing.
But if the levers are clashing on (say) the left hand side of the carb as you look at it, just whip the 2 screws out, spin the carb round by 180 degrees, screws back in and the levers won't be clashing on the left hand side any more, simples.
