5 wooden props for sale, not flown.
Stuart Atwill
Postby Stuart Atwill » February 11th, 2019, 5:52 pm
26x10 2 blade Xoar varnish finish. 10mm prop driver hole, 6 x 6mm bolt holes, 20mm centres. Slight compression mark from mounting, ground run. £15 plus postage
28x14 2 blade Menze S, varnish finish.10mm driver hole, 6 x 6.5mm bolt holes,20mm centres, slight mounting compression mark. £20 plus postage.
28x14 2 blade Fiala black and yellow factory painted, 10mm driver hole, as new. £25 plus postage
27x14 3 blade Fiala, black and yellow, home painted. 12mm driver hole, 6 x 5mm bolt holes, 17mm centres. Ground run only. £45 plus postage.
28x12 3 blade Fiala, black and yellow, factory painted. 10mm driver hole, 6 x 5.5mm bolt holes, 17mm centres not run or mounted. £50 plus poatage.
Best to contact me direct as I don't use this forum very often.
bartholomewbarn@hotmail.com
