Wood glue
Rosario Iannotti
Wood glue
Postby Rosario Iannotti » October 4th, 2019, 6:17 pm
Hi guys
What wood glue you people use to build your aircrafts?
Ross
Re: Wood glue
Postby Bob Thompson1894 » October 5th, 2019, 8:47 am
Most glues these days are very good. 30min epoxy for high stress areas, PVA wood glue, (Gorilla make a very good one) and various strengths of cyano. I tend to use Screwfix own brand Mitre Bond which comes with kicker - its thick and very strong. I dislike thin cyano but it has its uses- pound shop sell it for pennies. I dislike the foaming Gorilla glues, but some people swear by them.
Peter Siggins
Re: Wood glue
Postby Peter Siggins » October 5th, 2019, 10:06 am
Hi Rosario ,it depends what you are building - for white glue I use the blue bottle Evostick,available many places.
For epoxy both 30 minute and 5 minute I use Zpoxy and for very high stress e.g.firewalls I use hysol.
I only use very limited cyano - Zap thick and thin.Using the thin for joining balsa sheet.for wing sheeting.
All these glues are not cheap but over the years I’ve not found better.
Pete
Rosario Iannotti
Re: Wood glue
Postby Rosario Iannotti » October 5th, 2019, 6:37 pm
Thanks guys
paul hughes
Re: Wood glue
Postby paul hughes » October 6th, 2019, 9:57 am
Hi Rosario, beware that some pva white glues are heat sensitive and can become rubbery in high temperatures (even left in the sun on hot days). I prefer to use an aliphatic resin, it withstands heat and is easier to sand on a laminated edge. For high stress areas use epoxy. Personally i do most of my construction with thick and thin cyano, the thin to run into pre-made joints and thick for push together components, for large areas i.e. sheeting, i like aliphatic.
Stuart Solomon
Re: Wood glue
Postby Stuart Solomon » October 6th, 2019, 10:51 am
I agree with paul, never use PVA as it never sets hard and is difficult to sand. Aliphatic for general construction, epoxy for stressed areas and cyano for balsa.
Re: Wood glue
Postby Bob Thompson1894 » October 6th, 2019, 11:22 am
The Gorilla brand does set hard, its more like an Aliphatic. As I said, I dont like their foaming glue, but this is the best white glue I have found.
paul hughes
Re: Wood glue
Postby paul hughes » October 6th, 2019, 1:20 pm
Bob, I have never used gorilla glue, its too expensive. If it is a pva based glue then it will be heat sensitive. As we know Balsa loc is pva based and that sticks and unsticks with heat.
Re: Wood glue
Postby Bob Thompson1894 » October 6th, 2019, 1:40 pm
It is expensive, Paul, but its very good stuff. I imagine it is heat sensitive, but have not tried that. Good thing is it is not rubberry when dry.
