Bing Carb gaskets
chris-berry
Bing Carb gaskets
Postby chris-berry » October 27th, 2019, 8:58 pm
I'm looking for a supplier of gasket sets for a Bing 48 Carb. Does anyone know of a suitable source of gaskets for these carbs?
Peter Siggins
Re: Bing Carb gaskets
Postby Peter Siggins » October 28th, 2019, 9:38 am
Hi Chris you could try Rowena Motors Bangor N.Wales - tel no 01248 715552.He also has a website.
If he hasn’t got them he may know where to go
Hope this helps
Pete
Peter Siggins
Postby Peter Siggins » October 28th, 2019, 6:08 pm
Hi Chris just remembered the Bing carbs were fitted to some Stijl chainsaws - spares listed on eBay
Cheers Pete
chris-berry
Postby chris-berry » October 28th, 2019, 8:27 pm
Thanks Pete, i'll give them a ring tomorrow. Its for a Mackay 45 i've had for 10 years and i was the third owner.
Do you know if the Bing can be changed for a walbro on those engines? It s Front induction 45cc?
Peter Siggins
Postby Peter Siggins » October 29th, 2019, 9:45 am
Not sure if a swap would be easy - the heat sink may be a problem.
I have several scrap Walbro carbs - could send you one if you want a look - they have come off mainly chainsaws but I have one off a Zenoah somewhere.
Pete
David Berry
Postby David Berry » October 29th, 2019, 12:40 pm
Hi Pete,
I've just looked at the 45, it uses a pressure tapping and external pipe from the crankcase to provide the pulse for the carb pump diaphragm, whereas the Walbros I am familiar with use an internal drilling via the insulator block.
Dave B.
Peter Siggins
Postby Peter Siggins » October 29th, 2019, 2:01 pm
Hi Dave yes the Mackay 30 uses the same system with a Walbro carb - so it may be sortable,but for what it costs for a set of gaskets
I think I would persevere with the Bing carb initially.
Pete
chris-berry
Postby chris-berry » October 29th, 2019, 2:57 pm
Thanks Pete
Just ordered from Rowena.
Users browsing this forum: Bing [Bot] and 23 guests
