LMA Sky 120 Build
LMA Sky 120 Build
Postby Dave Parry » November 30th, 2009, 12:16 am
Hi all, now you might be thinking what’s the point of this thread it is only a trainer? Pretty straight forward I would of thought,’ well you might be right’ but this will be a challenge for me because I have never build anything before so I hope you will indulge me.
After opening the packing from slec which I have to say was pack very well, I dug out the plans, oh boy where do I start? Well thankfully the plans are not as daunting as they first look so after having several cup of tea and pondering over the plans I cleared the work table and started to identify the parts and numbering them.
The attachment numbering 1.jpg is no longer available
Once all the parts was numbered I then sat and had several more cups of tea, I think I was just putting it off wasn’t I, :roll: I mean how hard it can be!! ‘I’m sure I heard some say that before’ right time to get the Stanley knife out and with that I started to cut out the wing rib and all that stuff.
cutting out 1.jpg (34.63 KiB) Viewed 81373 times
Okay the next stage, arr you though I was going to say after several more cups of tea didn’t you well you would have been right only her indoors polity told me to ‘go away in short jerky movements :shock: ‘I have no idea what that means ‘I’ll never understand them’ :roll: so with losing access to my tea supply I had no option but to carry on, so with sandpaper in one hand and parts in the other I proceeded to sand all the rough edges down.
sanding 1.jpg (23.44 KiB) Viewed 81370 times
Next I assembled all the parts and got ready to do battle, I decided to do the wing first.
wing parts.jpg (23.06 KiB) Viewed 81371 times
Following the plan I found it easy to slot all the parts in place thank god I took the time to number them all I would have been lost if I hadn’t , I decided to dry fit all the parts first just in case I make a mistake.
assembley 1.jpg (22.51 KiB) Viewed 81369 times
assembley 2.jpg (26.57 KiB) Viewed 81370 times
assembley 3.jpg (23.2 KiB) Viewed 81368 times
Okay that's it for now.
Robert_Greenwood
Re: LMA Sky 120 Build
Postby Robert_Greenwood » November 30th, 2009, 1:17 pm
Brilliant!...Supprising how quick they come together!!
keep up the good work, :D
rob
Jason Griffiths
Postby Jason Griffiths » November 30th, 2009, 1:51 pm
Looking good 8-)
Thanks 8-)
Nick Reeves 3055
Postby Nick Reeves 3055 » December 2nd, 2009, 6:32 pm
i'm following this with interest. once i get my genesis finished i might have to get my self one of these. what engine are you planning on using??
cheers
nick
Postby Dave Parry » December 2nd, 2009, 9:59 pm
Rob, Jason & Nick, thanks for showing your interest, unfortunately I haven’t had chance to get back to the build this week, this is due to the LMA website and forum taken up all of my evening at the moment, ’lot of work to be done still’ so I hope to get back on it at the weekend, as for the engine I am going to be using a Zenoah 38, it will take a 26 but I like to have a little more up front.
Postby Dave Parry » December 5th, 2009, 6:58 pm
Okay on with the build, next stage, I needed to glue on the wing locater, well that what I call it, you know the bit that goes into the fuz to stop the wing flying off, anyway it took me a while to figure it out but I manage it,
wing locater3.jpg (22.29 KiB) Viewed 80991 times
wing locater1.jpg (20.51 KiB) Viewed 80993 times
wing locater.jpg (21.55 KiB) Viewed 80991 times
Once that was done it was time to turn my attention to the wing spar, now Tony Nijhuis has changed the design from the first batch that was sold, he has decided to have the wing so you can split them for easy transport, this involves putting in a box section, now following the plan I sourced the parts or so I thought, it said there is two 9mm spruce strips so I look at all the parts but I could not find them however I did find a length of spruce that looked right for the parts I needed, so thinking that must be it I measured and cut them to the correct length.
box section for wing spar2.jpg (20.6 KiB) Viewed 80988 times
Now when I came to dry fit them together it would not fit the spruce strips just seem to big, when I measured them I found it was 10mm not 9mm, gutted I was to say the least, but it was my own fault I should of checked instead of assuming ‘lesson learned’ so I checked the pack again but there is no sign of the 9mm spruce strips so not being a builder I had no stock I could use, job halted, time for a cup of tea and a think.
Right brew time over back to it, looking on I bypass the box section for now and fitted the servo try.
servo tray.jpg (21.12 KiB) Viewed 80988 times
After that I glued the LE & TE on and started to skin the top half of the wing, with the sheeting supplied using thin cyno to tack it then white glue.
Skined wing1.jpg (28.61 KiB) Viewed 80986 times
Skined wing2.jpg (26.19 KiB) Viewed 80986 times
Skined wing3.jpg (23.13 KiB) Viewed 80986 times
Okay thats it for now. ;)
PHIL ATHERTON 2400
Postby PHIL ATHERTON 2400 » December 5th, 2009, 8:20 pm
looking good son..........but don't forget to turn the plan over to build the other wing..........now i wonder who could ever do that build the same wing :lol: :lol: :lol: :lol: :lol: :lol:
ian redshaw
Postby ian redshaw » December 5th, 2009, 9:15 pm
Hi Dave, your 'wing locator', surely there is more than that and a couple of bolts? Does the locator plate have a doubler that goes either side of it and the rib or something similar? Looks like the bits go together well, did they need much 'fitting'?
Cheers, Ian.
Postby Dave Parry » December 5th, 2009, 10:50 pm
ian redshaw wrote:Hi Dave, your 'wing locator', surely there is more than that and a couple of bolts? Does the locator plate have a doubler that goes either side of it and the rib or something similar? Looks like the bits go together well, did they need much 'fitting'?
Cheers, Ian.
Hi Ian the second wing is a duplicate of the first so there is a wing locater on both wings also a bolt in each as well, very little filler its slots together like a jigsaw fantastic for the likes of me who knows nothing, but is learning much from this build.
ian redshaw
Postby ian redshaw » December 6th, 2009, 11:16 pm
Dave, in your 4th pic, the wing locator doubler I was on about is there, to the left of the locators you have shown fitted. I assume you have now fitted these doublers and there is nothing to worry about, I just couldn't see them fitted in any of the pics.
Cheers, Ian.
Postby Alan Cantwell 1131 » December 6th, 2009, 11:39 pm
it looks, to me, that the wing locator under rib, is just glued to the bottom of the root rib? is there a doubler fitted, inside the root rib, gluing over the rib, and the wing locator, therefore making them a one piece affair??
Postby Dave Parry » December 7th, 2009, 8:32 am
Ian, Alan thanks for your concerns, being my first ever build all help is appreciated, the pictures aren’t very clear However I have found out how sort that out with the camera now so I will take a few shots tonight and post them then you can tell me if it is okay I am sure it is but better to be safe than sorry.
Postby Dave Parry » December 7th, 2009, 11:58 pm
Okay here it is as promised, this is the way I have worked out how it is set up, I can’t see it going any other way following the plan. the first three pitures are a dry fit of the second wing the last two pictures are of the wing i have glued.
the hole is for a dowl to line the wings up and keep them in place and as i said both wings have a locater on them.
Postby DAVE JOHNSON » December 8th, 2009, 8:15 am
Dave---just looked at your pics,and yes ,you are doing it right,the locator is tied into the structure,and as you have seen around the 2009 events,the one i have is built the same,and i have stress tested on many occasions--a little bit more than the mild aerobatics that the plan recommends---the airframe is well designed by Tony Nijhous,so no need to alter anything.What colour scheme are you doing it in?
Postby Dave Parry » December 8th, 2009, 9:20 am
Thanks for the info Dave, I can now carry on with the build as I said in an earlier post better to be safe than sorry, Now colour scheme, ‘well that’s a good one’, I don’t know yet what I could ask is what is the best covering to use any recommendations will be appreciated. :geek:
ian redshaw
Postby ian redshaw » December 8th, 2009, 3:29 pm
Thats better now we see all the bits in place! Profilm or painted Solartex would be a great finishing material. I wouldn't use Solarfilm Polyester since in my experience it is a much inferior product in terms of finish and durability. Grand job Dave, Ian.
Postby Dave Parry » December 8th, 2009, 4:54 pm
Thanks Ian, i can crack on with the job now I know it is safe to do so Profilm hmm I like the sound of that, I have used Solartex before but don't fancy painting it after, anyway a long time of that yet will try and back to it this week, can't tonight Club AGM Zzzzzzzzzzzzzzzzzzz did someone say pint :geek:
Postby Alan Cantwell 1131 » December 8th, 2009, 8:00 pm
AH! now then, naughty lad :D you where hiding that full size tie in rib wasnt you? looks good to me, AND BOSSMAN, chill eh??
Tony Nijhuis 2280
Postby Tony Nijhuis 2280 » December 11th, 2009, 3:56 pm
Hi Dave,
Glad to see you're cracking on with it and building the Mark II version with the 2-piece wing......Even though I have a stack of models to fly its become my weekend hack....
The prototype was covered in Profilm by the way...the finish still looks great.
Must get on designing the low wing version ;)
Robert_Greenwood
Postby Robert_Greenwood » December 12th, 2009, 8:43 pm
Looking good dave!!! soon be in the air... :)
Keep up the good work...
