Century Jet Sea Fury
Charlie Cox
Postby Charlie Cox » January 10th, 2020, 2:05 pm
Century Jet Sea Fury, painted and fully weathered in Baghdad Sea Fury colours. Has a new, unflown Saito FG84R3 engine which has had 1 hours running time on the ground with a Keleo exhaust collector ring. Run on 15:1 Valvoline fully synthetic two stoke oil and is full baffled within the cowl. There is also Futaba engine temperature telemetry fitted. New 2200 mAh 2 cell lipo and opto-isolator for ignition power and a scale spinner and Xoar warbird prop to finish off New Hitec 645mg,s on elevators, rudder, ailerons, with standard Futaba's on flaps powered by 2 new Overlander Sport 3800mAh Nimh SubC 6v flight batteries. Currently this all runs through a Powerbox Mercury with twin Futaba R7008SB HV SBUS receivers, PLEASE NOTE: these will be removed and are not included in the sale. The fuselage is composite and has been fully refurbished, a scale dash and pilot, and the wing is foam cored with balsa and ply skinning and all fully glassed. The main and tail undercarriage are the correct Century jet retracts for this model with the mains being fully sprung scale units and the inner doors are currently sequenced through the Powerbox. An SM services sequencer can be provided separately All run through a Robart selector valve and Robart filler and tank As can be seen, the paintwork is fully weathered to simulate desert operations and its all been sealed in with satin fuel proofer. This paint job alone took a few hundred hours to apply. This is a large model with an 88" one piece wing, hence my reason for selling. Although it fits in my car (Discivery Sport) there is not a lot of space for anything else and I am worried about damaging it. Weight is 39 lbs dry so under the LMA weight limit. Of 20kgs. The model had been ground run for an hour but remains unflown in its present refurbished condition, mainly due to the weather. The Powerbox and receivers could be left in by negotiation but please take into account that I then have to replace them.
https://www.youtube.com/watch?v=q--ADoq ... LXGqtImkf4
Please call me on 07547679779 or e-mail charliecox1011@gmail.com
Price is £1950.
Located in Downham Market, Norfolk.
Baghdad Fury for LMA 1.jpg (334.41 KiB) Viewed 4440 times
Baghdad Fury for LMA 2.jpg (288.05 KiB) Viewed 4440 times
Baghdad Fury for LMA 3.jpg (250.76 KiB) Viewed 4440 times
Baghdad Fury for LMA.jpg (340.02 KiB) Viewed 4440 times
Charlie Cox
Re: Century Jet Sea Fury
Postby Charlie Cox » February 17th, 2020, 2:13 pm
Now Sold.
Admin, please feel free to remove.
Thank you
Charlie
