Temperature operated cowl flaps
Stuart Atwill
Postby Stuart Atwill » June 3rd, 2020, 2:33 pm
Many years ago I bought a ThermaCowl to operate the cowl flaps on my Corsair according to the temperature in the engine bay. It has worked perfectly for many years but I can't locate the original supplier in the states.
Does anyone know of a similar product?
Frank Skilbeck
Re: Temperature operated cowl flaps
Postby Frank Skilbeck » August 2nd, 2020, 8:00 pm
Only just seen this, but what radio system do you use? several have telemetry temperature sensor feedback which can be used to operate a channel, so you could have automatic operation using a servo via a spare channel on your transmitter.
Stuart Atwill
Postby Stuart Atwill » August 2nd, 2020, 8:10 pm
Hi Frank, I use a rather old Futaba T14SG. I know that Jeti are able to do this but I don't want to change all of my gear.
Frank Skilbeck
Postby Frank Skilbeck » August 3rd, 2020, 3:50 pm
Stuart, OK the other option would be to use an Ardunio and use that to control a servo, but that would need you to build and program a system, there a few examples on the web, i.e. https://www.instructables.com/id/Temper ... nd-Servos/
Steve Perry
Postby Steve Perry » August 3rd, 2020, 5:06 pm
Steve Perry
Postby Steve Perry » August 3rd, 2020, 10:15 pm
That instructables example is very basic and equivalent to replacing the potentiometer on a servo tester with a thermistor, no set end positions or anything.
Return to “Electric Stuff”
