Carf mephisto
Mike altham
Carf mephisto
Postby Mike altham » December 14th, 2020, 5:04 pm
Carf mephisto for sale. Had it up for sale previously but had quite a few dreamers and tyre kickers. This is now ready to fly minus turbine, batts and powerbox. It has had a patch repair at the rear section but this has been fully carbon fiber/herex repaired internally and is stronger than new. It needs painting still. It won't cost £800 to paint the back end as someone told me last time. It would cost about £50 all in and a few nights. I just don't have anywhere warm enough to spray.
It has zimmermann vector tube
Electron ev50s, brakes and control unit
Carf tank set
Intairco uat
Powerbox wiring throughout
Savox 1270s on the ailerons x 2
Savox 1270s on the flaps x 2
Savox 1270s on the elevons x 4
Savox 1270 on the rudder x 1
Savox 1270 on the pitch vt x1
Savox 1272 on yaw vt x1
Savox 1271 on the steering x1
All servos have alloy arms. Mostly secraft.
The whole setup is hv.
All carf ballinks and linkages.
Basically fit your engine, batts, pb and set up and go.
It's currently set up for a 190 turbine and the weight is coming in about 18.9kg dry. With the setup I have the cg is more or less perfect.
In total if this was new you would be looking at around 7.5k not including shipping.
£3450
Located Preston
Mike altham
Re: Carf mephisto
Postby Mike altham » December 20th, 2020, 12:29 am
Sfs open to sensible offers
Users browsing this forum: No registered users and 128 guests
