Wren Turbine engine 100i. Blue version. New.SOLD
Lyndon Brittain
Postby Lyndon Brittain » September 15th, 2021, 5:03 pm
This Wren Turbine engine has never been started or seen any fuel.
It's the 100i. Blue version. Everything you would expect when buying a new jet engine.
I am situated in St5 area of Newcastle under Lyme. Photo's on request.
£1000
Last edited by Lyndon Brittain on September 26th, 2021, 9:05 pm, edited 1 time in total.
Mick Hallsworth
Re: Wren Turbine engine 100i. Blue version. New.
Postby Mick Hallsworth » September 15th, 2021, 6:23 pm
Hello Lyndon
Is it this one….. TS 100i Turbine Engine
Statistics:
Max RPM 160.000
Idle RPM 42.000
Idle Thrust 0.35kg (0.75lbs)
Thrust: 100 N ( 22 lbs )
Size: 250 x 89 mm ( 9.8 x 3.5 " )
Weight: 1040 grams ( 2.25lbs )
Fuel consumption: 350 ml/ minute ( 12.3oz. )
Comes complete with;
Turbine, Engine Mount, Turbine/ECU Wiring, ECU /Receiver wiring, ECU, Data Terminal,
Fuel Pump, 1mtr. x 4mm Fuel Tubing, 0.5mtr. x 6mm Fuel Tubing,
Instruction Manual, 2 Year manufacturers Warranty.
Is it still in warranty ?
Mick Hallsworth….Clayton, Newcastle.
Users browsing this forum: No registered users and 89 guests
