Dave Collis 2296 wrote:Andy:
I wish I knew how to post a photo on here, however.....
On my 1/2 scale S/Walker, the hard points for the tail braces are lengths of 1/2" dia. hardwood dowel, let into the tail surface, full thickness. There is a hole in the centre, to which I used "Du-Bro" metal straps, bent to the req'd angle and bolted with a 4/40 bolt and L/nut. Tha cable I used is sold as "Down-rigger"stranded fishing cable, stainless, 150lb. breaking strength. The cable is terminated and crimped, (using crimps for that particular cable), at a "Sullivan" 4/40 eye-bolt (with the end of the "eye" soldered shut. The eye bolt is good because it is a round smooth surface as opposed to a sharp-edged hole in a piece of flat stock. The eye-bolt screws into a "Du-Bro forked clevis, which in turn is through-bolted to the steel strap.
Dave.
Tony Collins 1073 wrote:Hi Dave,
Have answered your PM. I have posted a couple of times on how to put your piccys on the forum but they seem to get lost with time ,so here is guidance from a previous post.
Max Dimensions for our forum are 600 wide and 400 high. Good luck
http://www.imageoptimizer.net/Pages/Home.aspx
PS To Dave Parry. Dave, should I start a new thread on posting images and you make it a sticky as so many guys seem to need help on the subject?
Tony Collins 1073 wrote:This picture posted on behalf of Dave Collis.
Waco Build 041
Andy, here is a picture of my t/brace on my 1/2 S/Walker.
Dave.
Waco Build 041
Dave.
stewart clifford wrote:hey man just too much maths just build the plane, fly it be happy.
Users browsing this forum: No registered users and 53 guests
