WENDell HOSETELER PT19
BOB WILLENBROOK
Postby BOB WILLENBROOK » May 15th, 2011, 3:54 pm
I have built a PT19 from a Wendlell Hostetler plan 114ins wing span weight 26lbs
sugestions as to what control throws I should try?
advice would be welcome
Bob Willenbrook
No 2074
BRIAN RAWCLIFFE
Re: WENDell HOSETELER PT19
Postby BRIAN RAWCLIFFE » May 16th, 2011, 1:05 pm
Bob,for your first flight as follows.
ELEVATOR-30MM UP.20MM DOWN.
RUDDER-80MM EACH WAY.
AIL-20MM UP. 15MM DOWN. [PROGRAM DIFFERENTIAL]
IF SCALE FLAPS FITTED SET AT 50 DEG.
IT WILL NOW FLY LIKE A TRAINER.
PS.A QUESTION FOR YOU,WHAT MATERIAL DID YOU USE FOR THE EXHAUST PIPES.BRIAN..
BOB WILLENBROOK
Postby BOB WILLENBROOK » May 22nd, 2011, 8:41 am
Brian
I used 13mm & 11.5mm O.D Ally tube,if you use 12ins long pieces you can heat bend to shape
Hope this answers you question
Bob Willenbrook
PS Sorry about the delay I have had a computer problem which is now sorted
