Simon Wright wrote:I suppose the most important question is, do 2.4 ghz systems suffer lock outs in flight and if so are they momentary or sustained.
Like I said at the beginning, does anyone have experience of lock outs, momentary or sustined on 2.4?
Simon Wright wrote:Thanks Stuart.
Momentary loss on AR500 and AR6200. Any more?
Bet it was a long 2 seconds when the plane was coming at you with no control .... got to ask. Did your throttle go to failsafe?
Simon Wright wrote:Tony,
I have already asked questions and so far the open forum has not answered them.
Can I respectfully ask where your contribution is?
Tony Collins 1073 wrote:When I first built my Precedent Stampe { which I still have ] in 1979, I decided that too much effort had gone into it to risk losing it from interference which was more prevalent in those days then it is now.
I decided to build a failsafe for all channels just in case { this was before PCM radio and I used my home built RCM&E radio gear] I had RAF Weathersfield to fly on with my club in those days and it was just magic.
When the failsafe was complete I took the Stampe to the airfield one fine sunday afternoon and took off. After gaining reasonable height I said to our club chairman standing beside me, " I'm going to switch my transmitter off now and see if it can fly on its own. I thought that he was going to have a fit but I switched off all the same. It continued in a gentle turn with the engine on fast tickover just losing height slowly. after about 30 seconds I switched back on and resumed normal flight. No one else knew that I had switched the transmitter off.
To this day I use the same settings for failsafe and do feel that an aircraft which stays on it its last inputs can be positively dangerous in certain circumstances.
My settings are throttle fast idle, Ailerons neutral, Elevator with some up in and rudder with a reasonable amount of left [or right] . This gives most aircraft a chance to fly through any interference.
We wont even talk about wiring, battery or switch problems as these should never occur on any properly built and maintained model under any circumstances. The other interference problem which may come from RF energy feeding back to the receiver via the servo signal wire should also be a none starter for any LMA member who is serious about safety as there are some well known counter measures for this.
I personally use the schmidtt digital inverter method which not only isolates the receiver but also boosts the
servo signal level.
I am not saying that this a panacea for all aircraft. but it will give even aerobatic types a chance to stabilize and give more time to see what it is going to do.
There, I will now stand back and wait for response. Be gentle with me as I'm getting on a bit.
Tony.
Users browsing this forum: No registered users and 31 guests
