As can be seen in the last piccy,6 satellite receivers have been spread around the wing---these have been mounted under little see thro covers so each can be checked for logging on etc,they have then been covered in masking tape ready for final sanding and filling etc,which will be done outside on benches in the garden when the weather permits.
Whilst waiting for the mains retracts,the second wing has been brought into the workshop---the top surface was filled and rubbed down earlier in the year for the display at Bradford,but the underside had been left with the cyprus stringers etc needing finishing,this was started today,and the first few sheets of balsa glued in place.With the poor forecast tommorrow,i will probably finish the section of covering around the wingtip/undercambered area,which is the awkward part--after this its much easier and straightforward--
- 2011-09-16_21.44.102nd wing sheet start.jpg (30.97 KiB) Viewed 13491 times
