92" Miles hawk Speed 6
Re: 92" Miles hawk Speed 6
Postby Phil Clark » May 17th, 2012, 5:44 pm
Final clear coat well under way.......just the sides/top of the fuz to do now. I've used Klass Kote 'Satin Clear' mixed 1 part clear, 1 part satin catalyst and 1/2 part reducer through an Iwata RG-3 0.6mm mini spray gun..............
Ted Oram
Postby Ted Oram » May 18th, 2012, 12:24 am
Looking great Phil.....looks like the maiden is not far away.
BTW...the Flying Scale Models magazine featuring the Miles Hawk Speed Six has just been released here in Australia, so I am trying to
to get a copy now
Ted Oram
Postby Phil Clark » May 18th, 2012, 8:22 am
Hi Ted
As soon as the clear coat is done, I just have the filler caps, fuel guages and the wing walkway to add and I'm done, so still more than happy to send you the magazne over if you strggle getting a copy.
Ted Oram
Postby Ted Oram » May 18th, 2012, 8:48 am
Hi Phil.....thankyou again for your kind offer of sending me the Magazine..........however I did manage today to order my digital copy and have downloaded and printed all
the MHSS info.
I notice that you have not tapered the rego lettering on the top and bottom of the wing........I only picked this up today looking at the 3 views.
I have not started my 1/4 scale version yet......I decided to finish off another project (recovering repainting my 1/3 Spacewalker) as I dont like to have too many projects on the go at once.
I will let you know when construction begins......it may be a bit small to start a thread on here.
Ted Oram
Postby Phil Clark » May 18th, 2012, 5:00 pm
All done........everything will be left alone now for a week or so to fully cure off before systems install.
Postby Phil Clark » May 18th, 2012, 5:09 pm
Mmmmm, you've noticed!!!! Dad had all the paint masks cut and I was part way through application before I got the magazione & 3-views in question. All other photos I'd found up until then were from such an acute angle you couldn't tell if the registration lettering was parallel or not.......hence the error :oops:
Postby Phil Clark » June 5th, 2012, 11:27 pm
Having just completed my move to new workshop premises, I hope to be back on with completing the 'Speed 6' ready for test flights shortly..............
Postby Phil Clark » August 25th, 2012, 8:33 pm
With customer building work coming out of my ears since the move to the new workshop, the Miles has made the 160 mile trip back south to Dad's place and he's now on with the final assembly & fit out......other than completion of the wiring harness to connect wing to fuz, the wings are now complete.
Postby Phil Clark » August 25th, 2012, 8:35 pm
more......
Postby Phil Clark » August 25th, 2012, 8:37 pm
.......last 2 for now.......
Postby Phil Clark » January 18th, 2013, 6:06 pm
Well it's taken him a while to get there (as I keep giving him jobs to do!!)....but the Miles is now all done and has had it's CG check today (Vanessa rig method).
1st engine runs & test flight as and when time & the weather permits
Richard scarbrough
Postby Richard scarbrough » January 24th, 2013, 9:29 pm
Very nice, will that be at Osbournby?
Richard.
Postby Phil Clark » January 24th, 2013, 9:33 pm
At some point yes.......not sure if I'll come down to test fly there, or Dad will come up here.......either way, I'm sure you'll see it around & about. I hope he's ganna let me 'borrow' it now & again so I can bring it to the odd show/flyin as well.
jimlambert
Postby jimlambert » January 24th, 2013, 10:19 pm
Top build as usual Phil ..... looking forward to seeing this one at the shows .......
Postby Phil Clark » January 25th, 2013, 9:27 am
Me too....but I can't take any credit for the built/covering.......thats all Dad's work, I just did the painting/clearcoat plus built the muffler.
andywynn
Postby andywynn » January 25th, 2013, 9:41 am
Phil Clark wrote:At some point yes.......not sure if I'll come down to test fly there, or Dad will come up here.......either way, I'm sure you'll see it around & about. I hope he's ganna let me 'borrow' it now & again so I can bring it to the odd show/flyin as well.
Very nice as usual Phil but hows it going keep up with my Mustang ??? :lol:
Postby Phil Clark » January 25th, 2013, 10:02 am
Well........it's about the same weight as your Mustang and has a DA50 up front for starters!!!
......but if that doesn't work, I'm sure I'll kick your **** with this :D
Postby Phil Clark » February 18th, 2013, 9:05 pm
Clark Snr looking justifiably pleased with himself after the 1st outing with the Miles at Osbournby at the weekend.........the DA50 had never been run, so this 1st trip was just intial engine runs and a general shake down........no problems reported other than the 24 x 8 being a little over prop'd for the new engine.
Postby Phil Clark » February 18th, 2013, 9:08 pm
Such a pretty machine, I had to share a few general walkround shots as well...........
Postby Phil Clark » February 18th, 2013, 9:10 pm
Another outing or two required to put several more tanks of fuel through the engine.....by that time we should have some better warmer weather so I can get stuck into some test flights.
