1/5th scale Vampire
David Jones
1/5th scale Vampire
Postby David Jones » August 7th, 2012, 10:25 am
I wasn’t going to write a build thread for this model, but I’ve been advised that some people might find it interesting. Its not as in depth as previous threads I’ve done, but I think you will get the idea.
I volunteered to build a 1/5th scale de Havilland Vampire for my mate, Mike Whitehead, while he was working away in Saudi Arabia. The model is from the Kerry Sterner plan, with a laser cut kit from Belair, and a wood pack from Slec. The kit and wood pack were collected at the LMA show at Cosford last year, and I started construction in early September.
I started by constructing the tail plane and fin/rudder assemblies. I like to start with the tail feathers on a plan build to get into the swing of things and learn how the designer has thought it through.
Vampire build 002 (Small).jpg (38.84 KiB) Viewed 22542 times
Vampire build 004 (Small).jpg (26.38 KiB) Viewed 22542 times
Vampire build 007 (Small).jpg (33.21 KiB) Viewed 22542 times
David Jones
Re: 1/5th scale Vampire
Postby David Jones » August 7th, 2012, 10:29 am
The assembly is straight forward, though horse shoeing the mini servos and wiring for the rudders into the fins proved a bit fiddly. Once done, the assembly was put to one side.
Vampire build 009 (Small).jpg (26.21 KiB) Viewed 22543 times
Vampire build 010 (Small).jpg (33.94 KiB) Viewed 22543 times
Vampire build 012 (Small).jpg (26.21 KiB) Viewed 22543 times
Vampire build history013 (Small).jpg (33.16 KiB) Viewed 22543 times
David Jones
Postby David Jones » August 7th, 2012, 10:32 am
Next up was the wings, which are really in three sections, a removable outer panel which is built at the same time as the mid panel, which in turn is later joined to the centre section forming part of the fuselage. These panels were built as per the plan, the only modifications I did was in the system for retaining the outer panel. The plan shows a retaining bolt which screws into a block in the joiner tube, and which is accessed via the wheel well. I wasn’t keen on this method, so I pinched an idea from the Zirolli Mitchell build, and made up a ply tongue that slides into the outer section, and is retained by a 4mm bolt, accessed from underneath the wing.
One method of forming the wheel wells is by utilising foam and lining it with 1/16” balsa. I decided to make up formers out of 1/ 4” balsa and made the walls up out of 1/32” rolled ply. With the top sheeting completed, the wings were then put to one side.
Vampire build history 015 (Small).jpg (50.7 KiB) Viewed 22542 times
Vampire build history 021 (Small).jpg (33.21 KiB) Viewed 22542 times
Vampire build history 022 (Small).jpg (34.8 KiB) Viewed 22542 times
Vampire build history 024 (Small).jpg (41.81 KiB) Viewed 22542 times
David Jones
Postby David Jones » August 7th, 2012, 10:35 am
The fuselage is built around a balsa crutch, supported on blocks cut to a fixed height to keep the centre line at 0 degrees incidence. The formers are added in turn and then the wing root rib is added, care being taken to ensure that the centre line of the root rib is at 0 degrees. Once satisfied that all is correct, the stringers are then added.
Vampire build history 027 (Small).jpg (45.03 KiB) Viewed 22542 times
Vampire build history 029 (Small).jpg (43.09 KiB) Viewed 22542 times
Vampire build history 031 (Small).jpg (42.01 KiB) Viewed 22542 times
Vampire build history 034 (Small).jpg (48.23 KiB) Viewed 22542 times
David Jones
Postby David Jones » August 7th, 2012, 10:37 am
The one piece top hatch extends pretty much the entire length of the fuselage, the stringers at the join being spruce strip, which are then separated after the planking has been added. The top of the wing roots are also sheeted at this stage and the nose leg was fitted.
Vampire build history 036 (Small).jpg (51.3 KiB) Viewed 22542 times
Vampire build history 041 (Small).jpg (44.14 KiB) Viewed 22542 times
Vampire build history 053 (Small).jpg (45.24 KiB) Viewed 22542 times
David Jones
Postby David Jones » August 7th, 2012, 10:38 am
The fuselage was then removed from the blocks and I couldn’t resist putting everything together for a quick photo.
Vampire build history 054 (Small).jpg (38.75 KiB) Viewed 22542 times
David Jones
Postby David Jones » August 7th, 2012, 10:40 am
Fibreglass mouldings are available for the air intakes inside the wing. I decided to save Mike some money and made my own up. Utilising the contours shown on the plan, I made up formers from 1/4” balsa and faced them with 1/32” rolled ply.
Vampire build history 060 (Small).jpg (40.92 KiB) Viewed 22542 times
Vampire build history 061 (Small).jpg (27.79 KiB) Viewed 22542 times
David Jones
Postby David Jones » August 7th, 2012, 10:41 am
The stringers and bottom planking were then added and sanded to shape.
Vampire build history 065 (Small).jpg (32.69 KiB) Viewed 22543 times
David Jones
Postby David Jones » August 7th, 2012, 10:43 am
The inboard flaps were then made up and provision provided for the servo mounts and hatches.
Vampire build history 067 (Small).jpg (20.77 KiB) Viewed 22543 times
Vampire build history 069 (Small).jpg (27.97 KiB) Viewed 22543 times
Vampire build history 070 (Small).jpg (31.03 KiB) Viewed 22543 times
Vampire build history 074 (Small).jpg (31.1 KiB) Viewed 22543 times
David Jones
Postby David Jones » August 7th, 2012, 10:44 am
I then returned to the wing panel to make up the outboard flaps and speed flaps. The method shown on the plan for hinging the speed flaps didn’t look very convincing to me, so I scrapped the idea of cut down Robart hinges and used Kavan flat hinges instead. Even now I’m not fully convinced that they would be strong enough to be deployed in flight. Time will tell, if they are not used in flight they will still be an interesting feature for static display.
Vampire build history 077 (Small).jpg (17.96 KiB) Viewed 22544 times
Vampire build history 079 (Small).jpg (25.74 KiB) Viewed 22544 times
David Jones
Postby David Jones » August 7th, 2012, 10:46 am
Back to the fuselage again. The nosecone was made up from soft balsa block and carved to shape, as were the fairings for the air intakes.
Vampire build history 085 (Small).jpg (33.32 KiB) Viewed 22544 times
Vampire build history 082 (Small).jpg (29.32 KiB) Viewed 22544 times
Vampire build history 088 (Small).jpg (27.05 KiB) Viewed 22544 times
Vampire build history 089 (Small).jpg (43.6 KiB) Viewed 22544 times
David Jones
Postby David Jones » August 7th, 2012, 10:49 am
The plan shows the booms being permanently fixed, but Mike wanted the boom/tail plane assembly removable for ease of transport. We came up with a system where I replaced the boom bearers fitted in the wing. The new bearers have a longer tongue that extends through the second rib in the boom. A sleeve is made up from two pieces of 1/4” liteply and the tongue is secured with 2 x 4mm bolts into captive nuts. For added strength, the boom bearers are lined on both sides with 1/16” ply.
Vampire build history 091 (Small).jpg (37.03 KiB) Viewed 22545 times
Vampire build history 093 (Small).jpg (41.13 KiB) Viewed 22545 times
Vampire build 109 (Small).jpg (46.15 KiB) Viewed 22545 times
David Jones
Postby David Jones » August 7th, 2012, 10:50 am
The boom bearer fairings on the wing were then made up as per the plan.
Vampire build 110 (Small).jpg (26.52 KiB) Viewed 22545 times
David Jones
Postby David Jones » August 7th, 2012, 10:53 am
Removable wing tanks were the next order of the day. These were made up starting with a 1/8” liteply core, the mounting tabs being laminated on both sides with 1/16” ply. The formers and stringers were added and the tanks planked and sanded to shape. The nose and tail ends were made up from soft block and the pylons are 1 /2” balsa on each side, shaped fore and aft. The tanks are retained to the wing by 2 x 4mm bolts through R5 into captive nuts where the outer panel joins. The bolts are recessed into R5 to allow for a flush fit.
Vampire build history 095 (Small).jpg (32.87 KiB) Viewed 22547 times
Vampire build history 094 (Small).jpg (39.5 KiB) Viewed 22547 times
Vampire build history 097 (Small).jpg (34.09 KiB) Viewed 22547 times
Vampire build history 098 (Small).jpg (33.77 KiB) Viewed 22547 times
Vampire build history 101 (Small).jpg (35.4 KiB) Viewed 22547 times
David Jones
Postby David Jones » August 7th, 2012, 10:55 am
The underside of the mid sections of the wings were sheeted and sanded. The areas around the main legs and nose gear were then covered in cling film and layers of glass cloth were used to form shaped pieces from which the U/C doors will be cut. The openings for the U/C were then cut out.
Vampire build 111 (Small).jpg (31.63 KiB) Viewed 22547 times
Vampire build 112 (Small).jpg (24.02 KiB) Viewed 22547 times
David Jones
Postby David Jones » August 7th, 2012, 10:59 am
The final work to be done was to make up the fairings/pods where the fins join the booms. These took some time to carve and sand to shape, the outer fairings having to be split in the area of the removable servo hatches. I could have omitted to make these, but now they are done, I think they do add some character to the finished model.
Vampire build 113 (Small).jpg (37.4 KiB) Viewed 22548 times
Vampire build 116 (Small).jpg (41.36 KiB) Viewed 22548 times
Vampire build 117 (Small).jpg (38.73 KiB) Viewed 22548 times
Vampire build 119 (Small).jpg (31.51 KiB) Viewed 22548 times
Vampire build 124 (Small).jpg (38.85 KiB) Viewed 22548 times
David Jones
Postby David Jones » August 7th, 2012, 11:00 am
This is now the end of my input into the project. To get to this stage has taken 400 hours, which I suppose will prove to be the half way mark. The model will be handed over to Mike later this year for finishing. He hopes to be back in the UK round about Christmas time, so in effect it will be his winter project. I’ve taken a total of 125 photos throughout the build which I can make available to anyone who may be contemplating doing one in the future. I hope this thread has been of interest to those who have read it, and I will return to it as the finishing process progresses. Dave Jones.
dave tilbury
Postby dave tilbury » August 7th, 2012, 8:59 pm
thanks for sharing Dave........excelllent work
just need to finish mine now.......
cheers
dave
David Jones
Postby David Jones » June 29th, 2015, 2:26 pm
It's almost three years since my last entry regarding this build. I'd handed the model over to Mike for him to finish it in 2012, he ended up working abroad a lot longer than he thought he was going to, hence the long delay. Since his return he's been plodding on with getting the model glass clothed, a coat of primer and all the installations ready for test flying. I'm glad to say we are almost there.
The first mod to the model, after some discussion, was to scrap the idea of a one piece hatch. The hatch was cut into three sections resulting in his being able to have a for and aft hatch, with a fixed center section, making the top of the fuselage more rigid.
Vampire 000.jpg (15.23 KiB) Viewed 21121 times
Vampire 00.jpg (16.45 KiB) Viewed 21121 times
Vampire 0.jpg (13.9 KiB) Viewed 21121 times
David Jones
Postby David Jones » June 29th, 2015, 2:31 pm
The engine, a Wren 100, the radio gear and all ancilliary equipment has now been installed and so it was time for an engine run up, which we managed to do this weekend.
Vampire 01.jpg (19.41 KiB) Viewed 21118 times
Vampire 07.jpg (30.09 KiB) Viewed 21118 times
Vampire 08.jpg (27.82 KiB) Viewed 21118 times
Users browsing this forum: No registered users and 65 guests
