z38's
Nick Reeves 3055
z38's
Postby Nick Reeves 3055 » August 22nd, 2012, 3:01 pm
hi all,
today i mounted and ran up the first of 2 z38's, one for me and one for a friend. my friends one happened to be in the mount first and i was very impressed with how easily it fired up and ran nicely.
i havent touched the needles yet but i have noticed something that seems odd to me. on a few occations when i havent flipped it hard enough, it has bounced of compression and happily run backwards until i stopped it. is this a common trait of the 38?
cheers
nick
Re: z38's
Postby Phil Clark » August 22nd, 2012, 9:28 pm
Yes.......they can kick back and run backwards if the starting flick isn't hard enough, but they won't throttle, you'll just get a pretty rough idle.
Re: z38's
Postby Bob Thompson1894 » August 23rd, 2012, 4:13 pm
Phil Clark wrote:Yes.......they can kick back and run backwards if the starting flick isn't hard enough, but they won't throttle, you'll just get a pretty rough idle.
now you tell me. Just gone through a whole thread on this on RCMF... I have one which is a pussycat, the other one runs backwards 2 or 3 times when starting, and I have been through everything from woodruff key to mixture to plug....
Re: z38's
Postby Bob Thompson1894 » August 23rd, 2012, 8:31 pm
Well, just got back from flying. Despite trying every bit of advice given to me, leaning out the slow running, setting the prop at 12 o'clock, whacking it as fast as possible, the bloody 38 starts backwards. Not just once, it does it a dozen times, then, for no apparent reason, starts the right way and runs like a sewing machine. Running out of options, the other one I have starts easily. (as did this one for four years!)
Nick Reeves 3055
Re: z38's
Postby Nick Reeves 3055 » August 23rd, 2012, 9:13 pm
could it possibly be that the engine is actually getting too 'wet' or over primed, and then running backwards on the prime like glows do?
Re: z38's
Postby Bob Thompson1894 » August 24th, 2012, 9:13 am
No, I have let it run backwards for 30 seconds, stopped it, and it still starts backwards. Going to swap the magneto for the one which works fine to see if it is something there. If I had any hair, I would be pulling it out...
Dave Hayfield
Re: z38's
Postby Dave Hayfield » August 24th, 2012, 9:31 am
I've got a z45 which doesn't run backwards but is the most spitefull engine I have ever had and I've had a few!. It kicks back and tries to get your fingers every time you try to start it, I've tried various prop positions and the fuel mixture is ok because when it starts it is fine. The prop position has always been in the same place for all of the Zenhoa engines I've had for optimum start. I've given in to it now and use a well padded glove!! :?
Thanet Model Flying Club
LMA 520
Peter Clare
Re: z38's
Postby Peter Clare » August 25th, 2012, 3:33 pm
These problems sound like ignition timing faults. I don't know how you would check this on Zenoahs. Petrol engines will kick back badly if too far advanced - running backwards could be retarded. ( Early BSA Bantam motorbikes would set off in reverse at traffic lights until they fitted a long delay cam to keep the points open after TDC ).
Re: z38's
Postby Bob Thompson1894 » August 26th, 2012, 12:41 am
this thing of mine does both! It bites, and runs backwards. The timing cant be altered if the woodruff key is intact, and it is. The engine runs perfectly once it starts the right way. Its just very odd....
John Rickett
Re: z38's
Postby John Rickett » August 26th, 2012, 5:23 am
Have you tried a heavier prop to give more flywheel effect when starting? ..........just a thought, not that I know anything about petrol!
Re: z38's
Postby Phil Clark » August 26th, 2012, 8:10 am
Have you checked the flywheel - magneto gap?
Re: z38's
Postby Bob Thompson1894 » August 26th, 2012, 9:35 am
Actually, no, Phil. As I said, the engine runs sweet as a nut, so not thought of that one. I shall give it a try.
Re: z38's
Postby Bob Thompson1894 » August 26th, 2012, 9:38 am
John- I would only ever use wood props on petrol, this is a Menz 19x10, but changing props makes no difference.
Re: z38's
Postby Phil Clark » August 26th, 2012, 6:11 pm
Even if the gap is a little on the wid side, it'll run OK once going, so it's worth checking. Loosen mag bolts, fold a regular piece if A4 printer paper in half, clap this between flywheel and mag (use magnets to do the clamping rather than finger pressure) and tighten the bolts........this sets the gap spot on.
Re: z38's
Postby Bob Thompson1894 » August 26th, 2012, 8:03 pm
Cheers Phil. Might be a while, as I'm off on holiday, but I will report back.
sean smith
Re: z38's
Postby sean smith » September 19th, 2012, 6:01 am
I line my props up with the prop hub mounting bolts (38's and 45) then give it a hard flick, both types start no problem.
Sean.
Users browsing this forum: No registered users and 31 guests
