Hi Stewart,
Glad to see another P-38 on the go. You seem to know about the booms 'issue,' here is how I tackled the problem. Instead of trying the beef up the structure I though the best way was get rid of the major cause of the weakness....ie the huge cut out for the wing mounting. Looking at yours, it isn't too late to do some mods on it! My wing tubes go into the central fuselage by about 3 rib bays, and I also added a 1/2" ali tube to the rear as well.
![100_35762 [320x200].jpg](./download/file.php?id=2999)
- 100_35762 [320x200].jpg (16.16 KiB) Viewed 17679 times
There are 4 M4 bolts holding the booms into place. The first two are accessed from the outer wing panel rib...the second two are access through some angled ali guide tubes...maybe the photos will explain it better!
![100_3566 [320x200].JPG](./download/file.php?id=3002)
- 100_3566 [320x200].JPG (12.95 KiB) Viewed 17679 times
The next photo is quite good at showing were I put my elevator and rudder servos!
![142 P-38 [320x200].jpg](./download/file.php?id=3001)
- 142 P-38 [320x200].jpg (20.51 KiB) Viewed 17679 times
Lastly...I would add a bit more strength to the tailplane (don't ask how I know!!) With those booms flexing in flight in blustery weather it can put a huge strain on the tailplane mounting points.
![134 Locheed P-38 [320x200].jpg](./download/file.php?id=3000)
- 134 Locheed P-38 [320x200].jpg (23.38 KiB) Viewed 17679 times
