Neil Hutchinson wrote:Now, if they could find all those crated Mosquitoes in China - that would be a coup!
TTFN,
Neil
Neil Hutchinson wrote:Redshaw, you hopeless child, Coup means successful action
Thats where you keep your chickens, Ian....ian redshaw wrote:Neil Hutchinson wrote:Now, if they could find all those crated Mosquitoes in China - that would be a coup!
TTFN,
Neil
Coup, is that Chinese for compost??
Ian.
Ken Bones wrote:Oh dear! I knew what you meant Ian.
Whoosh and whoosh again.
Bonzey
david whiston wrote:I think this is absolutely fantastic and I think / hope we will all be pleasantly surprised once the aircraft are excavated. I am not an expert at this sort of thing but, I have sort of made a living digging holes all over the world so I have a little experience. My understanding is that the "cases" are burried in what was at the time a dried up river bed which is why they are lying under 36 feet of material. Now the last time we did any digging in that region the "soil" was what we might consider as marl, lots of clay in it . If you have seen the size of the cases and there are photo's of these on the web they are very similar to what we would call an ISO 20ft container the rear door pillars are 6 inch square. Now if you saw the "time team " dig of the WW1 trenches do you recall that the timber uncovered in the "mine" shaft leading to the German lines was in excellent conditon despite being under water since the end of WW1 ??
So my theory is that firstly the cases are more than capable of supporting the weight of the material that is covering them, if the material does have a lot of marl in it then the closer you get down to the cases the more compacted it becomes and the more compacted it is then the less likely water can pass through it , sort of a clay jacket,, the only issue is were the cases placed on similar material before burial to prevent water coming up from the old river base . So water proof could also mean air proof ??? I do not know you guys know much more about spitfires than me , but my hope is that they are sealed ( mummifed ) by the clay, Ok the electrics will most likely be shot, but everything else ??? who knows. The Engine powering the first re pro fe2b built by the Vintage Aviator was I beleive ( I am probably wrong) discovered in a farm yard in Argentina ?? open to the elements,, it seems to be running ok today ...
Anyway I say best of luck to the team in Burma and I truly hope they strike gold
Return to “The Old Forum Lounge”
Users browsing this forum: No registered users and 38 guests
