Postby Phil Clark » October 19th, 2013, 10:43 pm
Back to the front muffler......................this has taken a lot of thinking about & plenty of test fitting & adjusting before it all fits in the space available.
With the inverted engine with a side exhaust, the manifold is running pretty tight up against the port side of the fuz. The 85cc Zimmerman canister we're fitting cannot run straight back from the header as it'll be touching the side of the fuz plus is too long to fit in front of the next former back in the fuz.
The next idea was to fabricate a shallow swan neck type header to allow the canister to be mounted centrally inside the fuz; problem now is that to get it far enough behind the rear mounted carb, this not only makes the header too long than the recommended 7", but it also means the back end of the canister encroaches into the front cockpit.
3rd option is to mount the canister diagonally from port to st/bd.......this allows it to fit in front of the front cockpit whilst achieving the correct length headed and leaving plenty of clearance around the carb for choke & throttle servos.
The header made up last week is extended a couple of inches to the rear with a straight length of 28mm st/st tube swaged at the end to allow it to slide over the piece it's connecting to. The 'kink' was then made up and silver soldered to the inlet of the canister.....this allows the Teflon joiner to run fore/aft rather than diagonally making it easier to push fit together as the canister is fitted through the nose gear opening, but the headed has to be pushed on through the opening in the firewall.
- Do335_169.jpg (45.68 KiB) Viewed 15171 times
Phil Clark on October 19th, 2013, 10:46 pm, edited 1 time in total.
