Alan Cantwell 1131 wrote:cut a stiff card template, and i use pacer canopy glue, clean hands, and a wet cloth to wipe away surplus
Alan Cantwell 1131 wrote:no, but i will give you years of experiance, 26 cc max, unless you want to be prop hanging it
Alan Cantwell 1131 wrote:to much oomph, as you put it, could well put you in the crap you are trying to get out of, but still, your plane, have fun, you can always throttle back
Phil Clark wrote:The DLA - BLE 30's are potent little engines..........way above what is recommended for this airframe. Fitting this much power is likely to cause you more problems than it solves, especially as a relatively inexperienced pilot (no disrespect). The saying 'you can never have too much power' isn't true to all airframe types. In a slow flying, lightly loaded type like this, it's definitely not what you want. This uses it's wings to fly not it's engine.
The 30's are also pretty light weight engines........you have an airframe with a VERY short nose and quite a long bulky rear end.......so why fit a light engine and run the risk of either having to shoe horn batteries further up front (where they probably weren't designed to go), or add extra nose weight.
This model is crying out for a simple, reliable Zenoah 26. It's more than enough power & being a little heavier than the 30's, it's 'useful' weight rather than a light engine + ballast. It's side induction, side exhaust so will fit in the radial cowl easily. Everything stacks up in the Zenoah's favour. Add 20 quid to your budget & buy one......
paul hughes wrote:Richard, Alan has been building and flying models for a very long time ( over 40 years) and has owned just about every commercial kit or model that has been produced. If he says 26cc max then thats what it is!
Why do you ask for advise and then tell people the advise is wrong! kind people are trying to help you.
As for cost, the smaller engine will be cheaper to buy and use less fuel, another plus is props are cheaper for smaller engines. Also the model will be lighter and threrefore easier to fly and land. The model you have is designed for a .91 2 stroke glow engine, which is about 15cc, so a 26cc petrol will be fine and about the right weight.
With the GeeBee model Ys we found that a 25cc powered model is no quicker than a 38cc powered plane, this is beause the airframe has so much drag it has a terminal speed and only a massive engine will pull it any quicker. Your monocoupe is the same span and although a high wing rather than low has a similar amount of drag.
In Short listen to Alan!
Alan Cantwell 1131 wrote:more years than you have been alivem there goes that feeling old again
Alan Cantwell 1131 wrote:2of the links dont work, the 26 would be ok, but would need a huge chunk out of the firewall, ive just got back from weston park, were i was running the swapmeet, i saw about 4zenoah 23s not one was more than £50 quid, you should have gone
Users browsing this forum: No registered users and 58 guests
