DH Beaver revamp - project big burther
richard armstrong
Re: DH Beaver revamp - project big burther
Postby richard armstrong » May 14th, 2014, 10:27 pm
update
cowl arrived today, £80 purchase, lucky i got it in the uk
it s a close fit but not quite close enough, little to small for the nose, i took a risk and did not pay off, all a learning curve for me
cowl being return,
took al the lead out today cowl started to fall to bits, weigh it, 1.24kg in the nose, hopefully a replacement motor will weigh approx 3kg, looks like i going to have to make a mould from the old one,
found a crack in the fuz today, right on the under-cart area, brushed on pva to stabilize, wonder if i should do what Alf did, put a sheet of news paper on to add a little strength?
at some point this must have had a heavy landing???
one of the primary wing bearers is loose, so it is epoxy time,
new tank arrived, that's a job for the weekend, servos not arrived, bummer,
first thing i need to is find my 3mm tap and dye set, have to fix the wot 4xl wing, for rougham, so burther is being shelved for a week or 2
and a chance to build the bank balance back up
need to build a new work bench to cope this the size of fuz and wings, torsion box i think
one job i must to do
richard armstrong
Postby richard armstrong » June 22nd, 2014, 9:06 am
need advice on engine
i know dave is going to say z62 for the beaver but i don't have z 62 money to spend so i found an alternative
i have compared both engine
would like to know your thoughts chaps
missed 2, z 62's on the bay, and couple hear due to not having the money at the time
see link
http://www.kingslynnmodelshop.co.uk/p24 ... wwodZGEAjg
http://www.ebay.co.uk/itm/AGM60-60cc-Tw ... 1e8d36dae6.
AGM60 60cc Twin Cylinders Gas Engine AGM 60cc Petrol Engine PK DLE60+UK Warranty
PerformanceOutput power : 7HP/8500rpm.
Displacement: 61cc
Idle Speed : 1400rpm/min.
Static Thrust : 15.2kg Pulling Force at 100 meters altitude
Static Thrust : 13.5kg Pulling Force at 1800 meters altitude
The specification of the aircraft propeller : 22×10; 23×8; 23×10; 24×8 2-blade
The type of the sparking plug : CM6 style spark plug×2.
Ignition Battery: 4.8 – 8.4v * Exhaust Amount : 20cm3.
Bore and Stroke : 36mm×30mm (1.42 in×1.18 in)
Ratio of compressio : 7.6:1.
Fuel: 30:1
Main engine weight : 3.43 lb (1555 g)
Exhaust pipe weight : 2.82 oz / 3.00 oz (80 g / 85 g)
Ignition equipment weight :7.44 oz (211 g)
Requires:Unleaded gasoline, oil, ignition battery & propellers
Postby Rob Buckley » June 22nd, 2014, 9:54 am
If you've got a quarter of a grand ready to go, hang fire for a week or three and a Z62 in your price range will appear soon enough.
As you know from the Wot 4, you'll spend from now until the second coming messing about with the Christmas cracker ignition unit that the cheap Chinese engines come with.
Get a magneto Zenoah & it'll just work.
richard armstrong
Postby richard armstrong » June 22nd, 2014, 10:00 am
Rob Buckley wrote:If you've got a quarter of a grand ready to go, hang fire for a week or three and a Z62 in your price range will appear soon enough.
i will look into mag version
Last edited by richard armstrong on June 22nd, 2014, 11:23 am, edited 1 time in total.
richard armstrong
Postby richard armstrong » June 22nd, 2014, 10:13 am
richard armstrong wrote:
true rob but i f-ed around for a while so i could not get the position of the throttle servo right, to shut the throttle of completely, and it was my first time with that size petrol engine, now all running sweet as a nut, now i have a spare carb, as the spring broke on the original, want to make sure, that the carb would shut off properly before, i let it loose hence a lot of hesitation and this being my first petrol engine plane, now i have a new engine on the way for the monocoope
rotomax 25cc , use the same prop size as the wot4m but i might up it to 18x8 to knock the rpm down a bit
by the way i am bringing to cosford, the wot 4 and hopefully the coope for flight testing
Last edited by richard armstrong on June 22nd, 2014, 10:15 am, edited 1 time in total.
Postby Alan Cantwell 1131 » June 22nd, 2014, 10:14 am
need a head banging smiley, why dont you just contact the guy first,
Joshua Henderson
Postby Joshua Henderson » June 22nd, 2014, 10:58 am
Richard, I have a zenoah 62 cdi version.
I got it off here a while ago and run it a few times but the ignition was "lent" to a mate, and Ive never seen it since ;-).
The engine has not done a lot
Pm me for details if your interested
richard armstrong
Postby richard armstrong » June 22nd, 2014, 11:06 am
Alan Cantwell 1131 wrote:need a head banging smiley, why dont you just contact the guy first,
i was thinking out load and typed and posted i relised mate, now i can't delete that single post, :oops:
Postby Alan Cantwell 1131 » June 22nd, 2014, 11:12 am
you should be able to at least edit your post, and Joshua, some blooming mate, i would be kicking his door in, the ignition unit can be replaced with a recell unit from just engines, good units
Postby Bob Thompson1894 » June 22nd, 2014, 11:49 am
When, at the LMAs busiest show, do you intend to do that? :?:
richard armstrong
Postby richard armstrong » June 22nd, 2014, 12:10 pm
Bob Thompson1894 wrote:When, at the LMAs busiest show, do you intend to do that? :?:
if possible after hrs bob
for the coope to be ground tested and run up throttle to set etc, and then if rules allow for ic after 5pm then up up & away, but when i am 99% sure of my set up, but that all depends on what the rules will be for this show, and hopefully if there is a slot available for the wot4 to but put up by an experienced pilot, again that depends on if everyone turns up for there flight, but like say, ONLY if, and allowed! and within certain weather conditions
they only way i am going to get better at flying is just to get on with it!
i am also bring my baby coope as well for after hrs fun, also my new t28, but not sure if there is after hrs flying this year, at last note i heard that this was under discussion, but i might be wrong!
Postby Alan Cantwell 1131 » June 22nd, 2014, 12:42 pm
be a lot better if you attended a fly in, or even your local field,
richard armstrong
Postby richard armstrong » June 22nd, 2014, 5:53 pm
Alan Cantwell 1131 wrote:be a lot better if you attended a fly in, or even your local field,
flyin's i do attend when i can afford to !
local field, is a no go as Newark club is indoor only with access to a runway, langar is the next closest club, but that's a no go for me, along with Grantham is next but, still waiting outcome of barkston site, if that gets sorted then we will see!
